WTD pre face lift Carin cage and CD changer cage
Started by feeutfo, 08 May 2011, 10:07:16
From a Pre face lift.
I am after the CARiN cage that holds the unit in the boot on the pas side.
And the CD changer cage that holds the blaupunct(?) unit in the first aid cupboard, this is going to hold my Bose amp in my face lift as I have done away with the Bose shelf. So if there are any size variatiants over model years then it doesn't mater.(think they are all the same, but anyway)
Cheers
Chris.
All saloon prefacelift CD Changer cages are same size, and suitable. You will need to drill a couple of extra holes in the amp, not that that is an issue for you :y
MutantCav
Should have this sorted now guys. Thankyou  :y
Bit of trial Telematics fitting to commence now then  :y
