Author Topic: Hub Cap Lock Bolt Needed  (Read 3874 times)
Lesopc
  • West London
  • Worlds Biggest GM Fan
« on: 31 July 2011, 01:54:00 »
Hi guy's, i have a F/L Miggy with the 7 spoke alloys fitted. These are the ones with a Vauxhall centre cap covering the 5 studs and held shut with a locking bolt. The prior owner seems to have lost 1 of these lock bolts (3 prong type) and replaced it with a standard bolt. Does anyone have a spare lock bolt?
IM me with price including P&P if you can help as this is a nuisance when getting new rubber as well as a risk in terms of wheel theft. Thanks.
Why oh why was there never a V8 Omega????
Such a missed oppurtunity.
Look forward to the Cadillac ATS & ATS-V. Maybe a re-badged one will replace the Miggy as a RWD runner?
Re: Hub Cap Lock Bolt Needed
« Reply #1 on: 31 July 2011, 10:00:13 »
can you provide a photo of what you mean...
I cant picture a standard fl wheel that has a bolt cover though  :-/
I think its just a locking bolt your after but not sure?
and the position of the 3 holes varies on every car using these, so the next bolt (probably) wont fit your key...
« Reply #2 on: 31 July 2011, 10:02:39 »
ahhh, is it one of these your after?
Lesopc
  • West London
« Reply #3 on: 31 July 2011, 10:22:19 »
Exactly these ones. Just need a Hub Cap Locking Bolt.
Lesopc
  • West London
« Reply #4 on: 31 July 2011, 10:23:55 »
Please see the other reply with photo. I do believe that the 3 prongs are spaced out as a complete and equal triangle on these bolts/keys???
Lesopc
  • West London
« Reply #6 on: 31 July 2011, 10:34:08 »
Just like these....
Lesopc
  • West London
« Reply #8 on: 31 July 2011, 10:36:06 »
trouble may well be....gls's arent broken as much as others due to lack of saleable toys
Lesopc
  • West London
« Reply #9 on: 31 July 2011, 10:57:23 »
Not too sure what you mean or the relevance???
« Reply #10 on: 31 July 2011, 11:37:52 »
Nothing sinister....Just the main sellers here buy Elites / CDX's for selling as spares as the more toys provide more income, there is less money to be made from a GLS so people with the parts you need will be fewer.
guessing your best bet is someone who has upgraded their wheels, but even then may be unwilling to sell as it splits up a set.
Good luck all the same, but at least you can get a new set for a reasonable price if needs be.
You mention security.....I really dont think these will secure your wheels though - a pair of pliers , or 2 nails and a screwdriver is the max you need to remove them....no substitute for locking wheel nuts (not that they give you much more tbh)
Lesopc
  • West London
« Reply #11 on: 31 July 2011, 11:49:20 »
True enough, but it means they need to carry those tools with them which is still not entirely likely.
It was worth the ask.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #12 on: 31 July 2011, 12:12:20 »
have a look at your local scrapyard, that will be your best bet to get the locking bolt you are after, or as already suggested fleabay and get the set, at least you know the key will fit all the bolts  :y
Lesopc
  • West London
« Reply #13 on: 31 July 2011, 12:55:39 »
Fleabay is around a tenner for a set of 4 plus key, but these bolts a a standard lug spacing (exact triangle) meaning that any key should fit any bolt (????) as all the same. I was just looking to see if anyone has a single one no longer required instead of getting a whole set. I am looking into getting a spare 7 spoker and cap off fleabay to replace the ugly/odd black steel spare so i will probably now need 2 anyway as i have sourced both wheel and cap seperately without required bolt. Thanks again all.
Hannah Judes Dad
    • the misses round the bend
« Reply #14 on: 31 July 2011, 14:21:24 »
Are they the same ones that also were fitted to pre face lift CDX's ? If so I can help you out with some.
