FS - Heated seat cushion ............
Started by I_want_an_Omega, 07 August 2011, 21:10:42
I_want_an_Omega
I have a seat cushion for a MFL. It's the foam cushion to which has been stuck the heater element pad in the factory.
If you have non-working seat base (cloth or leather) then this is what you need. Replace the foam cushion in your defective seat by putting the existing seat cloth or leather cover on top.
Has two connectors - one to the multi-connector where the seat plugs into the main car loom, the other to the heated rear section of the seat.
This can fit either the driver of pass side simply by re-routing the cable to the back section. The actual seat cushions are the same for both seats.
If fitting to a leather seat then the connector to the back heater is different - but its only 2 wires which can be easily jointed (I'll include instructions) by soldering or crimping (I hate Scochbloks  :-X).
This will only fit MFL seats.
Hope that all makes sense.
Looking for £20 plus postage.
mindaz
Vauxhall/0pel 0mega 2.5 , 2002 , CD
I_want_an_Omega
mindaz
ok thanks,
it would be easier to decide  ;), to buy or not  :D
I_want_an_Omega
Ok, the good news is that the heater pad can easily be unstuck from the seat cushion. I'll post it for free in the UK and only a small amount for other locations.
The so/so news is that the connector for the rear heater pad is missing - but it will still work if the wires are joined.
mindaz
I think , it must be 4 pads  ::)
2 for back section and 2 for base section,
I am talking about rear seats  ;)
how much pads do you have ?
thanks
I_want_an_Omega
I'm talking about a front seat - and base only.
So that's one pad - as in the picture
twiglet
QuoteI think , it must be 4 pads  ::)
thanks
It looks like a front seat to me...
mindaz
QuoteI'm talking about a front seat - and base only.
ok thanks
everything is clear now  :)
mindaz
btw, I am searching 4 heating pads for rear seats  ;)
is it possible to get ?   ::)
I_want_an_Omega
