Auto box sump
Started by mahony, 09 August 2011, 23:55:49
mahony
Hi, im after a Ar25/35 auto box main sump ( my filler plug is rounded off ),
            Cheers in advance  :y
Get a nut welded onto the plug, then undo it with a spanner. ;)
Varche
I've got one but it is in Spain.
I would imagine postage would be a tenner but that is just a guess I would have to take it off and take it to nearest post office 20 miles away.
If you do go the route of another one might be worth having a drain plug put in the bottom before fitting?
As Albs says you could always get a nut welded onto the plug. Far easier.
mahony
There is one on ebay but im not paying £38 delivered, thanks varche but i think the postage would be to much, im gonna try and file two flat sides to the existing plug and take it from there  ;)
unlucky alf
Ive got one here if you cant get your plug out, I had the same problem but managed to get some stilsons to bite on the edge & hey presto!. :y
mahony
Thank's Alf, will pm you if i cant get the plug off!!
