WANTED please - Battery securing bolt & bracket
Started by SJKOO01, 12 August 2011, 19:06:35
SJKOO01
Are there any breakers on here that happen to have going spare, a good condition battery securing bolt and the battery securing bracket itself please.
Found out from the Mot that the bolt has snapped, so nothing holding battery on, manage to get it through with a rachet strap of all things!
If you can let me know how much you want + post - Thanks.
Cheers.
Have you managed to remove the busted bolt from the captive nut?
SJKOO01
No not yet Rob.
Was going to drill through and then re-tap hole / captive nut if I can.
Not easy though as there is still a lot of bolt in the bottom of the nut and not easy to remove unfortunately  :-/
Same happened on mine. Drilled bolt out and used a bog standard nut & bolt. If you can`t get bolt out can`t you just drill another hole a few mm away and use that. Got a fairly new bracket you can have buckshee if you want
SJKOO01
Would appreciate having the bracket please, let me know how much postage and for the bracket - Cheers  :y
QuoteWould appreciate having the bracket please, let me know how much postage and for the bracket - Cheers  :y
Buckshee means sod all, nowt, zilch. PM your addy and I`ll stick it in the post
SJKOO01
Never heard of that before  :-?.
Cheers  :y
Cheers  :y
Sheltered life ;D ;D
SJKOO01
#8
Cheers  :y
Yes  ::)
Been in a nice warm room that the Health and Safety bunch would be proud of, along with a really good jacket with extra long arms which always made me feel warm... mind you, always thought the fasterns were in a strange place  ::)  ;D :P
twiglet
#9
QuoteSame happened on mine. Drilled bolt out and used a bog standard nut & bolt. If you can`t get bolt out can`t you just drill another hole a few mm away and use that. Got a fairly new bracket you can have buckshee if you want
Rob, I like your style!  :y Man after my own heart.  8-)
zirk
#10
I thought Buckshee was illegal in the West Counties, or am I thinking of Muffin the Mule.  :-/
