F/S Bosch Park Pilot System
Started by RobG, 20 August 2011, 18:53:47
Removed from `52 plate so later smaller sensors currently Rubens Red. £100 posted. Tested working. Bumper available if needed.
To get speaker from near sunroof runner >:( back through into boot had to cut the 2 wires (arrowed) so these will need soldering/heatshrinking back onto speaker wires.
If you intend to do any towing and have the GM plug behind the boot trim you should have a black/white wire with a single spade connector (arrowed) so just connect plug from Parkpilot loom and splice the looms` black/white wire into the corresponding colour cable on your rear light cluster (reversing)
Reduced to £70 if anyone`s interested, or I`ll stick `em on mine :)
humbucker
Hi Rob is the kit complete and are the sensors working without fault? Ta.
http://www.irmschermv6.com | #irmscherMV6
PM with your requests.
