F/L Hid`s F/S
Started by RobG, 21 August 2011, 20:20:41
Pair of Hid`s complete with bulbs, ballasts & levellers. Lenses are VGC. Adjusters intact. £50 posted or £40 collected.
you have customer again ;D
will you ? :y
They`re RHD lights Cem, is that OK for you?
QuoteThey`re RHD lights Cem, is that OK for you?
hmmm.. that sounds bad..wont pass Mot.. I forgot sorry.. :-[
I need to send a letter to UK officials to finish this road side difference.. I hope they will take it serious ;D :y
I did same when a Eurolander wanted projectors too  :-[
Wonder if its worth breaking a car in Spain, should get a lot more for parts?  :-/
I believe various production cars only have a flat beam as standard, so if you flick the lever to cut off left hand upsweep of our RHD dipped beam you'd have flat beams ............  :-/ :-/ :-/
What kind of lights do you have at the moment? I wonder if you could do a bit of mix & match with your lights and Robs HIDs? I've never looked at doing so but I wonder if it'd be difficult to convert RHD lights to LHD it's  only the angle of the 'bulb' relative to the reflector with normal tungsten bulbs.  :-/ :-/
its possible to convert them, but its likely that we cant isolate like the factory and after it will mist inside..
better someone buy it and use without any problem , they were so shiny :'(
will ask a friend tomorrow, if its possible without damaging it :y
Quotewill ask a friend tomorrow, if its possible without damaging it :y
Quote..
but its likely that we cant isolate like the factory and after it will mist inside...... /quote]
If you follow the guide on fitting aluminum adjusters it's easy to split them. There's enough black goo in the first place to let them seal again when rebuilding them. I'm sure you won't have misting problems.  ;)
Quote..
I'm not very confident for those kind of jobs  ;D :-[ :-X  (last time I repaired mid it was worse than before ;D)
however, a friend who installed my xenons also repaired the sunroof (thanks for guide Rob- we looked while working on it)) probably can..will ask him..
but still not sure opening those nice hids is a good idea :-/
Quote...
They come apart easily enough if you take your time & don't rush. You just gently slice through the goo with a sharp knife eg Stanley knife  :y
Quote...
will you make a trip to here soon Andy ?  ;D :y
Quote....
I wish I could say yes, but SWMBO won't fly anymore  :(
Quote....
ok then.. you drive until France, then I'll be the driver..
just pm the time.. serious :y :y
