Facelift 2.5 Elite breaking for parts.
Started by albitz, 19 August 2011, 07:10:43
As above.Colour is z20H Blue (Nocturno ?)
Im planning on keeping the wheels, but most other parts are available.
Headlights and exhaust and are spoken for at present.
Cloth seats in grey with memory £50.
Engine - only done 75,000 miles. Lifters have a very slight tap until warmed up, otherwise runs fine,I will put some wynns lifter treatment in over the weekend and that may cure the slight tapping.Cambelt was changed at 40,000 miles but that was 8 years ago, so it needs doing. - £150.
Headlamp washer jets, with tank,pipework,pump,relay etc - kit to convert your car if it doesnt already have washers £50
Will add other parts and prices later.
Any parts required - just ask.
Really tiny part but could I buy the hinge pins out of the drivers fusebox lid?!
If they are there, you can have them. 0.4p each plus vat.Im open to offers/ negotiation. ;) ;D :y
Im at work until morning.will have a look tomorrow. ;)
Omega_Dan
Omega_Dan
Stallion
Agemo
I could do with the nearside door mirror, (just need the casing, but obviously would buy the full mirror), please send a price posted. It would save me a spraying job.
Will check on condition tomorrrow (Im at work tonight) and get back to you Agemo. :y
Agemo
wakeyomega
Hi
I've just posted a wanted post then saw this post. I'm looking for a replacement Bose door speaker. My Omega is a faceleift elite estate.  The speaker has a Bose label with
233 080A Woofer 150mm SQ 2 ohm
Hoping to get one in the next week before my son takes the car on holiday?
Thanks Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
I will take the one out of the drivers door and check its the same. :y
Update on the engine.First time I started it up the lifters were very slightly tappy.It hadnt been started for quite a while.
I have started it up several times since and it is very quiet and smooth.Even Mrs A (who has no interest in these things whatsoever) walked past when it was running and said "that sounds really quiet and smooth". :)
