Wanted - SAI pipe?
Started by dbug, 18 September 2011, 17:25:02
For 1998 2.5 V6 Elite Estate - hose pipe that runs from SAI pump under n/s front wing to valve which is bolted to radiator fan assembly.
WHY?
May well have one here.Will go and have a look, back in a minute. :D
Yep, got one.just took it off the car.Can post tomorrow if you want it. :y
About 2 feet long, with a couple of kinks about half way along, yes ?
QuoteYep, got one.just took it off the car.Can post tomorrow if you want it. :y
Sounds like the one - guess it would be about 2' long, around half inch dia bore
PM on way mate
Yep, pretty sure its the right one. :y
PM replied to. ;)
I_want_an_Omega
I ripped the SAI system out completely. It's not needed for MOT and makes it a lot easier to get to the cambelt. There is quite a few pounds of weight saving with the pump, metal pipework etc. removed
Feedback for Albs - good clean hose, very fast delivery, very well packed - top notch service.
Think its only right we acknowledge good service from fellow OOFers  :y
Thanks mate, appreciate that. Doesnt happen too often. :y
