Author Topic: DVD copy help  (Read 2607 times)
Allenm
  • Milton Keynes
DVD copy help
« on: 02 August 2007, 16:08:57 »
Just to be clear NOT movie DVDs....
I need some help on copying a Data DVD,  I am trying to create some up to date POI entries on my built in Sat Nav (not Vaux).  I know that the Map Discs can be copied, because I have the original and a backup of it that came with the car.
What I can't do is sucessfully make another backup of it?  It is a DL DVD+R which is what I am writing to, but so far any method of copying I have tried has resulted in a very expensive useless DL DVD+R.
Having trawled the net for ages, I can't seem to find a utility that will either tell me extactly the format of a disc so I can recreate it, or let me do a copy of the data and all the subcodes.  All I seem to find are utilities to let me pirate movies, which is not what I want.
Anyone know of any utils out there?
Cheers
Merv
Craig_R
  • Watford
Re: DVD copy help
« Reply #1 on: 02 August 2007, 16:10:59 »
For Backup Just make an ISO image of the disk to your Harddrive and then you can burn an image to disc if required
AVS Disc Creator is a good Free program for DVD data disks and CD's
« Last Edit: 02 August 2007, 16:13:04 by CraigR »
Mod's
[To be Fitted]Reverse Sensors
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: DVD copy help
« Reply #2 on: 02 August 2007, 16:15:05 »
I use Alcohol 120%. It is an ISO application which takes a 'snapshot' of the disk and creates a virtual DVD player which then reads the disk as if it were a physical disk.
I have had no problems with it at all.
Hope this helps.  :) :)
[size=24]        [/size][/b]
megaomega123
Re: DVD copy help
« Reply #3 on: 02 August 2007, 16:23:18 »
Easiest thing I have found is  DVDdecrypter  :y
Lordmpl
  • Norwich, Norfolk, UK
  • 2.5 V6 Auto CDX - Big Bertha
Re: DVD copy help
« Reply #4 on: 02 August 2007, 16:34:11 »
I use nero, and just click copy disk, it wirtes an iso then copies it to a new disk, if its DL, you will need a dual layer writer to do it.  :y
I Love my Omega, wanted it for so long, now it's in my grasp, it's not getting away!!
Allenm
  • Milton Keynes
Re: DVD copy help
« Reply #5 on: 02 August 2007, 16:40:01 »
It is a DL writer, and I am writing to DL discs.
Tried so far.. Nero, Blindwrite, Clonedvd, manual drag and drop of file structure . . loads of pricey coasters!
Golfbuddy
  • Cornwall
Re: DVD copy help
« Reply #6 on: 02 August 2007, 16:51:08 »
Did the writer come with any bundled software? May be worth having a look at their website if you haven't already tried that.  :y
Re: DVD copy help
« Reply #7 on: 02 August 2007, 22:09:20 »
Does UltraIso make a good iso copy? Then make mods, then reburn the iso (most s/w can burn iso)
Re: DVD copy help
« Reply #8 on: 02 August 2007, 22:09:54 »
Not movie disk.
Allenm
  • Milton Keynes
Re: DVD copy help
« Reply #9 on: 03 August 2007, 10:56:51 »
Haven't tried that one.. I will have a go.  What I am really after though is a util that can analyse the original so I can work out what is going wrong.  DL media is still not cheap enough to keep wasting them  >:(
Re: DVD copy help
« Reply #10 on: 03 August 2007, 10:59:05 »
Have you tried writing at a low speed?
Allenm
  • Milton Keynes
Re: DVD copy help
« Reply #11 on: 03 August 2007, 11:02:36 »
I have, but most of the software decides on the best speed for me,  which on a new drive it determines to be quite high!
« Last Edit: 03 August 2007, 11:02:56 by Allenm »
Martin_1962
Re: DVD copy help
« Reply #12 on: 16 August 2007, 15:17:58 »
Try using IMGBURN to burn the ISO
