Author Topic: Air con  (Read 3205 times)
megaomega123
Air con
« on: 16 August 2007, 10:33:21 »
How long on average does an air con recharge last?
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
Re: Air con
« Reply #1 on: 16 August 2007, 11:08:52 »
Depends on whether you have a leak or not ;)   My manual says re-gass every six years  :o  saw a poster in garage recently which suggested get it checked every two.  If you have had it re-gassed recently and it's stopped working then you may have a leak or other problem, the system will prob lose around 15% of refrigerant each year.   :y
The faster you go the bigger the grin.  Trade card user.
Re: Air con
« Reply #2 on: 16 August 2007, 11:28:26 »
For £45 Kwik Fit will re-gas your system and if it doesnt improve by 10% theres no charge :y
megaomega123
Re: Air con
« Reply #3 on: 16 August 2007, 12:00:35 »
I haggled with Kwik Fit and got them to £20 for recharge :y Not bad to find out if it leaks or not. I think it is ok.
Re: Air con
« Reply #4 on: 16 August 2007, 12:59:52 »
Any decent a/c place will tell you if the system is air tight as part of vac process.
Usually stated by manufacturers to have a/c serviced every 3 yrs.
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
Re: Air con
« Reply #5 on: 16 August 2007, 14:08:05 »
I tend to go for every two years - this includes changing the receiver / dryer.  Some think that this is a bit over the top, but it keeps my A/C running.
megaomega123
Re: Air con
« Reply #6 on: 16 August 2007, 14:13:33 »
Mine doesn't have receiver/dryer, earlier model. They said they would check the system then recharge, so finger crossed. Can't complain for £20
x25xe
  • Hayes, Middlesex
Re: Air con
« Reply #7 on: 16 August 2007, 14:18:13 »
I think that I am correct in saying that all car A/C systems have a receiver / dryer - it is a black cylinder object in front of the condenser.
megaomega123
Re: Air con
« Reply #8 on: 16 August 2007, 21:05:19 »
Oh well, got the car back and was told that it only took half a charge. He said that there were no leaks etc. but only took half.
Any reason for this?
He didn't charge me and I have to take it back next week so he can give it a good clean out and try to fully charge it.
Re: Air con
« Reply #9 on: 16 August 2007, 21:12:02 »
was it vac'd properly?
megaomega123
Re: Air con
« Reply #10 on: 16 August 2007, 21:15:14 »
Not sure. I will check when I go back. It is Kwikfit after all and their picnics don't have their full quota of sandwiches ;)
Re: Air con
« Reply #11 on: 16 August 2007, 22:09:27 »
Did their can of refigerant run out during filling?  ::)
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
Re: Air con
« Reply #12 on: 16 August 2007, 22:46:28 »
As far as I am aware Kwikfit don't do a vac on it, they just check for lubricant and if there's some there they just top up the system with refridgerant!
Hence it only takes ten minutes, and only cost £45.
It's not a proper re-gas!
Re: Air con
« Reply #13 on: 16 August 2007, 22:57:39 »
They told me that the reason it took an hour was that they vacuum it down first. Then again, what they say, what they do and whether they know there's a difference....
The machines they use are automated - so they just connect it up and start the program.. any idiot could..
RolandL
  • Doncaster
Re: Air con
« Reply #14 on: 16 August 2007, 23:01:04 »
Halfords offer a similar service.  £50 to have your air con re-gassed, they use aerosol canisters (measure and charge) which contain 500gms & £39.99.  So, given that you may need to put upto  max in (950gms) they will charge you for two cans  :o and the £40 is for some spotty oik to connect it to the feed line and press a button, all for over  £100    :o :o
 I would rather go for a vac, pressure test and re-gass at £60 ish
