Author Topic: Smoke gets in your eyes  (Read 6227 times)
chelskifl
  • chertsey
  • Yaba Daba Do Omega I Luv U
« on: 15 May 2007, 19:58:22 »
 :-/ i have just had a bad day.. were should i start. went to take the beast out today to try and get some new self leveling shocks.. oh the car is a 1997 omega elite 30.i estate, anyway driving along 30 40 mph then suddenly a huge bolder or rock fell from a lorry did not have time to miss it went under the car what a noise i thought the engine was going to fall out. i thought i was lucky .. then suddenly smoke started coming in fro the vents i meen smoke that bakerlite smell smoke !! thinking electrical the car is going to catch fire.. pulled over fliped the bonnet and smoke was coming from the drain hole drivers side,, oh f)ck ,,,, so i turned the ingnition off !! it would not turn off engine still running.. panic set in so next battery terminal disconnect.. no tgools but i did have a leatherman multi tool so diconnected the battery "still running the engine compartment was filled with smoke. i thought this is it goodbye old friend.... then i thought ok relay time so i flip the relay lid right send and removed relays at random. then the car stopped . still smoking from the area ..  but dying down
went back home taxi got some tools test equipment removed the cover to find....... the alarm siren dead short, burnt straight through the casing. now looking under the car i could see were the bolder had hit front cat and back box, but how the hell would that cause the alarm siren to short out like that...
i removed the sirem/horn made good the wire , no plug or socket left. fixed everything down reconnected the battery.. thinking the worst i put the key in hay presto everything worked 100%
bar setting clock ect. plugged in dinostic reader no faults. central locking works immobilise works..
i could have lost the old girl, if i had not done what i had i think well i know she would have been toast.. has anyone any ideas. oh and also has anyone got a spare alarm horn and plug with cable if anyones breaking the gm number is 90508618 pj ,, long ditty but i just had to tell you all very strange. car is due for mot soon needs new shocks.. was going to fit normal and bybass the pump, but i think i will treat her ,, help her recover hahaha
thanks, oh just joined today :y
amigov6
Re: Smoke gets in your eyes
« Reply #1 on: 15 May 2007, 20:21:23 »
 :(So you've had a good day then? >:(
« Reply #2 on: 15 May 2007, 20:30:05 »
Hi and welcome to the forum :y
I think you had a lucky escape. I dont suppose you got the wagons reg No :(
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #3 on: 15 May 2007, 21:10:10 »
Great escape -  the sequel.  :o
Welcome to the forum gald you're ok :)
« Reply #4 on: 15 May 2007, 22:24:28 »
Welcome to the forum :)
Seems everyone has had a bad day today :(
Can't answer why it should happen.
Is it the horn or the powersounder?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #5 on: 15 May 2007, 22:36:50 »
Welcome to the forum :y
I like red cars
Bo Bo
  • Coventry
« Reply #6 on: 15 May 2007, 22:48:09 »
Hello & welcome  :)
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #7 on: 16 May 2007, 10:05:05 »
Phew.......that was some introduction, sounds like you saved the day in the end though!! :y
« Reply #8 on: 16 May 2007, 12:02:17 »
That sounds nasty!
I wonder if the power sounder shorted between the permanent live and switched live hence the problems switching everything off? .. and then the wiring overheated, of course. No fuses blown, I take it?  >:(
Glad you managed to save it though, thanks to quick thinking on your part, by the sound of it. It's not always easy to think things through and do the right thing when you're panicking!
I'd take a little time to trace the wiring back from the power sounder and check there's no damage further up the loom.
The power sounder only provides the Thatcham approval part of the alarm in any case. I think you'll find the main alarm horn still sounds, but of course it can be silenced by removing the battery.
I'd be happy to do a post-mortem on the old power sounder if there's anything left of it. Sounds like it would be good to know how this happened!
DaveL
  • Nr. Cupar, Kingdom of Fife
« Reply #9 on: 16 May 2007, 12:45:00 »
Welcome to the forum chelskifl, i would say a warm welcome but i think you have nearly had that already.  :o :o
Very quick thinking on your part, if it would happen to me i wouuld like to think that i could have responded like wise. Perhaps your noniker should be 'cool as a cucumber'. ;D
 8-)
DaveL
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #10 on: 16 May 2007, 18:08:57 »
Hello and welcome to our forum  :y
Martin_1962
« Reply #11 on: 16 May 2007, 22:03:40 »
Hello & Welcome :y
Not a nice thing to happen :(
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #12 on: 21 May 2007, 00:40:00 »
Welcome & happy Omega motoring  :y
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
« Reply #13 on: 22 May 2007, 16:46:46 »
A warm welcome to the forum!   8-)   :y
Jeeeeezzz .....  ::)  ::)
MikeDundee
  • Costa Del Peckham
« Reply #14 on: 22 May 2007, 18:14:21 »
Hi and welcome to the Forum m8 :y
