Author Topic: bulbsDash bulbs  (Read 1361 times)
Dazzler
  • Haverhill, Suffolk
bulbsDash bulbs
« on: 16 August 2007, 21:50:11 »
Does anyone know the alternative p/n for the climate panel bulbs. 5 x 9120630. As Vx want £2 each + vat :o
Are they R509..........?? What colour base are they.
My car is a mini-facelift 1999
Cheers
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: bulbsDash bulbs
« Reply #1 on: 16 August 2007, 23:30:12 »
Hello I changed the bulbs in mine beginning of last month I have just been trying to find the post I out up for it  ::) I had the same problem using vx parts it was going to be £15 to change all 5  >:( I found that you can remove the bulbs from there holders and just the glass part these were 47 pence each from local car spare shop  ;D you will need 5 x type 236 (12V 1.2W) They are small wedge based lamps same shape as the side and indicator wing lights just a smaller version  ;) Hope this is some help its a bit of an awkward job getting  a couple out of the back of the dials  ;)
Dazzler
Re: bulbsDash bulbs
« Reply #2 on: 17 August 2007, 12:39:59 »
Are the bulbs not soldered to the housing then :-/ If they aren't that's great cos 10 is about £3 :)
LFF64
  • HADDENHAM BUCKS
Re: bulbsDash bulbs
« Reply #3 on: 17 August 2007, 22:58:12 »
No they are not soldered in they are just a push fit  ;) they may be awkward to pull out due to there size but they will come out eventually  :) Like I said yesterday they are not the easiest lampholders to get at in the climate unit I had to use a pair of reallly thin long nose pliers to get one out  >:(
Re: bulbsDash bulbs
« Reply #4 on: 18 August 2007, 08:50:43 »
Or a 7mm (?) socket seems to fit most ;)
