Author Topic: r90400225 - Part no?  (Read 2274 times)
« on: 19 August 2007, 15:02:34 »
r90400225 is stamped on my sump. Is this the p/n? Would the same be stamped on a suitable donor sump?
hotel21
  • The Kingdom of Fife
Re: r90400225 - Part no?
« Reply #1 on: 19 August 2007, 15:18:52 »
Would think so James.   Is yours a Veccy B or C, and what engine/size, please?
I can view a piece of 'paper' that I have but it is limited as it is now quite old and does not show all upto date listings as regards vehicles/types, if you follow.
Call on mobile if its easier.   :y
« Reply #2 on: 19 August 2007, 15:43:28 »
It's a B, 2001 51 reg Broocie, with the Z18ZE engine lump :y
hotel21
« Reply #3 on: 19 August 2007, 15:46:38 »
Unfortunately, the gibbles I have only shows upto the X18XE and X20XEV engines.....
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #4 on: 19 August 2007, 17:50:41 »
mine lists X18XE, X18XE1, Z18XE, Z18XEL ... but no match for P/N 90400225 ...
« Reply #5 on: 19 August 2007, 17:57:14 »
could you please send me the PDF / doc from your software, for the sump removal procedure? cheers
email is on profile...
sounds2k
« Reply #6 on: 19 August 2007, 23:42:21 »
What's the engine code? I've emailed you the procedure for X18XE1 / Z18XE / Z18XEL ...
« Reply #7 on: 20 August 2007, 00:04:17 »
Z18Xe, you're a star :)
sounds2k
« Reply #8 on: 20 August 2007, 00:53:37 »
email sent  :y
« Reply #9 on: 20 August 2007, 07:43:14 »
Replied to your PM - the sump part numbers do seem to suggest it is from 1.8 only.
