X25xe to frontera /megasquirt info
Started by peterklepec, 10 March 2008, 21:24:11
peterklepec
Hi all!
We ported x25xe (1997 omega v6) to frontera and killed imobiliser in the process. So we opted for megasquirt instead.  I have great problems getting info on several key components that i need to start tuning. (we successfuly startted engine but did not get much further ) i will list the components that i need info on, and all data will be greatly apriciated.
- I dont know firing order on cylinders.
-can someone confirm thatx25xe has 60 teeth on crank wheel and missing 2 teeth.
-lamda sensor is it narrow band or wide band (i know there are 2 of them)
what would be correct pulse timing for cranking.
these are info that i found and i base my settings on(i picked info up from calibra of the same build year):
Engine: C25XE Ecotec
2498cc - 24 valve - 6 Cylinder
Multipoint (sequential) Fuel Injection
Quad Camshafts
Catalytic Converter
Bosch Motronic 2.8 ECU
front wheel drive
169 bhp @ 6000 rpm
167.4 ft/llbs torque @ 4200 rpm
148 mph max
0-60 mph in 7.3 sec (0-100 kph in 7.8 sec)
0-7000 revs - 6750 redline limited
maybe someone has base settings for this engine?
this is my first post here and english is not my native language, so please be kind.
I thank you for reading this post any help will be greatly apriciated.
You may be better posting in the Omega Help section, as more likely to get an accurate answer in that section :)
Darth Loo-knee
waspy
thewelshman
I drive a crumpet puller. albeit stale crumpet
zirk
Hi, welcome to the forum and good luck with the project :y
Bo Bo
file28
welcome to thr forum hope you mak it
tmx
QuoteHi all!
Quad Camshafts
Catalytic Converter
front wheel drive
169 bhp @ 6000 rpm
148 mph max
Is the engine an X25 or a C25 firstly
im only familiar with an x25 the lamba sensors are wideband sensors and the ecu is actuall a motronic 2.8.1 or can be a 2.8.3 depending on yr only difference is a PAS sensor firing order is 1-2-3-4-5-6 according to haynes
the cranksenor i have no idea i know its a hall effect sensor but thats all i know
Tafty
tomoco
Hi and welcome....good luck with the project :y
Martin_1962
MikeDundee
