Author Topic: An Error Has Occurred!....  (Read 1694 times)
Markjay
  • London
« on: 21 August 2007, 22:59:19 »
Trying to access the thread 'Project Tractor Ultimatum' on http://www.omegaowners.com/forum/YaBB.pl?num=1187731261 ,
I get the following error message:
'An Error Has Occurred!
You are not allowed to access this section.'
Any ideas?   :o
« Last Edit: 21 August 2007, 23:00:29 by markjay »
Alas, no more Omegas....
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: An Error Has Occurred!....
« Reply #1 on: 21 August 2007, 23:02:00 »
The thread is jinxed!!  :-?
[size=24]        [/size][/b]
Taxi_Driver
« Reply #2 on: 21 August 2007, 23:06:02 »
The thread seems to have disapeared.....maybe TB deleted it at the same time you tried to access it  :-/
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #3 on: 21 August 2007, 23:11:00 »
Yup change of hearts  :)
Markjay
  • London
« Reply #4 on: 21 August 2007, 23:25:15 »
So good news then... TB's ultimatum is off...?
« Reply #5 on: 22 August 2007, 03:17:14 »
I'd guess he's deleted the thread, or removed it from view.
Probably taking a bit of chillout time before next actions... understandable when a project goes a bit t*ts up. I've had a couple like this - especially the mint GLS I transplanted an engine in, and it never started. I sold it as scrap, it was soul destroying after hoisting a replacement engine in.
Jaime's TD car has just had nightmare probs from start to finish... and I really do wish him every bit of luck with the final bits.
Jaime, I'm by no means an expert on the TD, but if you need a bit of assistance etc then I'm only an hour away :y
Your perserverance is admirable, and I have no doubts that this car will be a goodun when finished...you WILL get there...
« Last Edit: 22 August 2007, 03:17:55 by JamesV6CDX »
Markjay
  • London
« Reply #6 on: 22 August 2007, 10:56:32 »
Yep, understandable indeed, I usually feel that way after around 5 minutes into the job when the jubilee clip securing the air intake ducts fails to undo!  ;D
« Reply #7 on: 22 August 2007, 20:25:09 »
Any ideas?   :o
yes, deleted.
