Author Topic: The sump is off - next steps  (Read 3106 times)
« on: 20 August 2007, 20:21:31 »
I've taken the sump off the Veccy.. .not a bad job at all, once I'd located a hidden bolt!
Thread is well and truely gone.
Now, do I go out and spend on a tap/die/helicoil/drill set - or, do I get a local engineering place to rethread it for me?
Martin_1962
Re: The sump is off - next steps
« Reply #1 on: 20 August 2007, 20:43:48 »
Easy realy James - if it is ally get it helicoiled - not worth rethreading
theolodian
  • I need a new avatar.
« Reply #2 on: 20 August 2007, 20:48:45 »
Someone should have brought that up before he removed the sump . . .  ::) :)
« Reply #3 on: 20 August 2007, 20:57:45 »
They did.
But I wanted to pull the sump off anyway, as it was leaking a tad at the front.
Reckon if I phone somewhere in the morning, they'll do it same day if I bung them some cash?
Dazzler
  • Haverhill, Suffolk
« Reply #4 on: 20 August 2007, 21:00:26 »
They did.
I would mate, alot cheaper than buying the kit ;)
Martin_1962
« Reply #5 on: 20 August 2007, 21:02:34 »
We have been discussing it for a while - helicoiling is best
« Reply #6 on: 20 August 2007, 21:03:20 »
Now remove the engine, and put in v6, then remove bodyshell and put Omega one on...
« Reply #7 on: 20 August 2007, 21:04:47 »
Would like nothing more than a V6 Gas Omega...
« Reply #8 on: 20 August 2007, 21:05:51 »
Oh forget the lpg rubbish. No point in having Omega, then losing the boot. May as well get a smaller car.
Martin_1962
« Reply #9 on: 20 August 2007, 21:09:15 »
You should have got the 2.0 running on it then sold it for a grand after getting the Elite working - you know where I live and the offer of help with LPG
Taxi_Driver
« Reply #10 on: 21 August 2007, 07:34:17 »
Thats why you need to get an estate  ;)
« Reply #11 on: 21 August 2007, 08:11:07 »
Given that you are doing a bit of mobile mechanic work, a sump plug helicoil set is going to be a very useful asset.......so get the kit.
On a sump, the old trick used to be to grease the tap etc well so the swarf sticks to it and put the old oil through it again to flush it out. That way it can stay on the car and you dont have the nightmare task of trying to re-seal the dam thng when re-fitting it!
« Reply #12 on: 21 August 2007, 09:48:51 »
Points noted - and I think it's a good idea. I would hate to be helping someone with a car, and have the sump thread break!
I always always use a torque wrench on such things - that way you can't be blamed for being ham handed (unless you cross it!)
I reckon my sump's been overtightened before.
Can you recommend a decent tap and helicoil set I should buy?
And while I'm on the case, what's the best sealant for resealing my sump?
« Reply #13 on: 21 August 2007, 13:44:04 »
The sealent used on the V6 sump is the same as that used for the oil cooler plate which should be well upto the job.
I dont know off hand the thread pitch and size of the sump plug, I would think its about an M14 but what the pitch is I dont know...
Paul M
  • Edinburgh
« Reply #14 on: 22 August 2007, 11:29:20 »
Sounds like a good idea.... if you can find a smaller car that's rear wheel drive, can carry 4 (or even 5) people comfortably, has reasonable performance (less than 8 secs 0-60), while managing a petrol/diesel equivalent of 60+ MPG, all for £1500 or less, sign me up please.
Until then I guess I'm stuck with this Omega with only half its boot space available, even though I've still never managed to actually fill the boot :y
Not everyone uses their car as a glorified van :P I mostly use mine for carrying people, and unless a law change allows me to carry passengers in the boot of a saloon car, having any substantial boot space is irrelevant to me ;)
Page created in 0.023 seconds with 16 queries.
