Author Topic: Skype  (Read 1439 times)
Nickbat
Skype
« on: 27 August 2007, 23:17:26 »
For various reasons, I want to get a Skype connection. I've downloaded the software and today bought a Logitech headset at Tesco.
Problem 1: the microphone doesn't seem to work. Look like it's going back in the morning
Problem 2: I have a basic audio setup connected to the soundcard on the PC. How can I set up the Skype headset so that the conversation does not come out of the speakers, just through the headset? Should I use the mobo's audio connections or will that cause a conflict? Should I abandon these connections and get a bluetooth headset instead?
I could probably work out most of these myself, but it's so much easier to ask here, especially if you're a lazy git like me.  ;D
Incidentally, Skype seems like Billy Bunter when it comes to eating up my resources.  :o
Re: Skype
« Reply #1 on: 27 August 2007, 23:22:08 »
Might be worth checking in the volume control application that the fader for the microphone is not fully down. If you've got multiple audio devices i.e. not just n analogue headse plugged into the sound card you should be able to selevt which ones the Skype application uses.
Nickbat
Re: Skype
« Reply #2 on: 27 August 2007, 23:28:28 »
Cheers, Kevin. I did check the fader first, but I'll take a look at the device usage as well.  :y
Re: Skype
« Reply #3 on: 28 August 2007, 09:32:10 »
Not a fan of Skype for a number of reasons, mostly around costs if you want a proper number, and the fact that it needs PC on.
I personally use a SIP based solution, with a hardware SIP to PSTN adapter.
The provider I currently use is sipgate.co.uk (coz its free to sign up, and you get a geographic number), and a Linksys PAP2 adapter so I can plug in normal phone (or phone system in my case).  Visiting anyone for a few days? Just take the PAP2 and plug into their broadband (adjusting firewall if necessary) ;)
SIP, though, like most proper VOIP protocols, is time dependent, so if your broadband is being thrashed, you can get dropouts, bit like mobile phones in weak areas.
Its free, I suggest anyone try it (with software 'phone'), if it doesn't work for you, then nothing lost...
Re: Skype
« Reply #4 on: 28 August 2007, 10:16:04 »
That's useful information, Jaime. I've been thinking about how to keep my boss connected a little more seamlessly (and less expensively) than he is at the moment. He keeps sloping off to Spain, you see ::).
A box that he can simply take over there and plug into his broadband connection (assuming VOIP is not blocked by his provider) would be a very neat solution.
Re: Skype
« Reply #5 on: 28 August 2007, 10:49:03 »
Yup, may need some initial router config down in Spain (f/w, nat forwarding (though most routers have an alg for SIP now, so may just work)).
As said, the downside is it is very sensitive to bandwidth, so you need a line that does not get too busy. Try with a softphone first, and see what results are like....
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: Skype
« Reply #6 on: 28 August 2007, 11:08:23 »
I'm with sipgate works well.
The only thing against is they stopped letting people with other sip providers calling your sip number
and never told anyone. Found out while looking at a sip forum.
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Re: Skype
« Reply #7 on: 28 August 2007, 11:44:40 »
Sounding even better. Excellent excuse for an all expenses paid p*ss up business trip to Spain. ::)
Do you have any experience with wi-fi VOIP phones? Presumably a similar product just packaged differently?
