Author Topic: Hello PEOPLE...2.5 CDX....Runnin...but not movin  (Read 7407 times)
iOmega
  • luton
  • Can't See Meee....
« on: 08 January 2010, 12:04:48 »
 :D....Finally here! Hello Gents, am Nathan, just signed up because it was in my best interest!  ::)! Am 25 and have been a grease-monkey for... 9 years now! I wanted a car that was rear wheel drive and since my insurance went down last November...it might as well be a v6...Hadn't driven for 2 years and thought if am gonna spend money on driving again, I might as well enjoy it!! I remembered the only v6 i ever drove during my apprenticeship...my boss's 2.5 elite!
      Of all the lovely cars I drove, I never forgot that car...especially on the motorways! ...And really this is the first v6 I've really worked on! So am still learning!!
      I bought a 2.5 cdx omega Auto in Oct 2009...off eBay from Essex for 350 quid, with 112,300 miles in gray! It had a oil leak and high temperature! But it was a very tidy bargain, I didn't realize 350 quid could buy so much!! I had to rethink what I was gonna do to the car.
      The car had 3 owners in the same area in Essex, it seemed to be a Sunday car!! Reading up on it...on this site..I stripped the cooler out and dipped it in BnQ de-scaler, which was as good as new....then refitted!
       Fitted new Spark Plugs, new cam cover gaskets (major oil leak), full service, crank shaft sensor, new battery, Fuel Additive, cleaned the breathers and found 3 fault codes. ( X2 Immobilizer Faults, X1 Crankshaft Sensor Fault code).
       I didn't realize the car had a dash A/C cooler, and it was left on/open...hence the new battery, and the A/c pump went after some miles, so got one after a struggle!
The front air in-take is all off and the A/c pump is out, so i bought a timing belt so it can be fitted at the same time.
      The only problem i have is not being able to get hold of a v6 timing belt fitting tool kit at a decent price!.... Now... being honest.... I've only done a few timing belts in my short career... each one was new to me...easiest was the fiesta, cos i started my apprenticeship at Ford Dagenhams!!...
       I know the v6 timing is easy to do... but the only part I don't get is the part when i have to line up the actual roller tensioners! Been doing a lot of reading and there's a lot of conflicting opinions on how they should be lined up! In fact...there's a little conflict in opinion on how to do the timing procedure over all...i.e... (whether to remove the spark plugs or not first).!! So am still in doubt if I can do it exactly right, because it seems its an easy timing belt to change, but a lot room for error!!
    A lot of mobile mechanics have let me down this Christmas, lying they would TURN UP with the tool kit and fit the belt for me...an easy 80.00 quid for them as the car was stripped down already and I was willing to box it up again!!...So that was Christmas and new year celebrations out the window...I just got desperate in fact, just seeing the car sitting there in the snow, the car has spent Christmas  with the fan belt hanging off covered under snow, with all the bits in the boot! the new battery is now flat too!! ..
      Got new pads, Omega 2000 door strips, A/C pump...new black Clear Glass angel lights.
I got 4 months Tax and 5 Months MOT with it...and that's running out soon ... and I haven't really got the chance to drive it!... so PLEASE Gents...anyone who can give me some input to get this car on the road...I would much appreciate it thanks!
Does anyone know a place where I can still buy or rent a timing tool kit please?
Can anyone do the timing for me and I sort them out please, then I can learn something new too! :-[!?!
Am also thinking about fitting the early dash Philips Carin (VDO) SAT NAV system, but I have a 1996 Omega so am not sure on compatibility!  :exclamation  :question ! please?
« Last Edit: 08 January 2010, 12:06:38 by makeveli3511 »
    • E250 Est / Elroq
Re: Hello PEOPLE...2.5 CDX....Runnin...but not movin
« Reply #1 on: 08 January 2010, 12:07:07 »
Hello & Welcome  :y
« Reply #2 on: 08 January 2010, 12:14:15 »
Hello and a very warm welcome to you! :y
For the best response to your querries, please enter each in the section appropiate. :D :D ;)
« Reply #3 on: 08 January 2010, 12:15:17 »
Hi, welcome to the forum.   :y
In the OOF shop there is a CD/Vid on the V6 timing.  Best £3 investment you will ever make.   :y
http://shop.omegaowners.com/index.php?main_page=product_info&cPath=3&products_id=7
« Last Edit: 08 January 2010, 12:16:33 by skruntie »
Welung666
« Reply #4 on: 08 January 2010, 12:17:22 »
Welcome to OOF Nathan :y
iOmega
  • luton
« Reply #5 on: 08 January 2010, 12:50:05 »
If only you guys knew how I've been sweating with this car in the cold!!  Now answers are just falling into place!!..You guys are amazing!! didn't think I'd get a reply for another 3 days or-so!!...thanks People! am gonna buy the CD asap! and am gonna have redo the ecu test after fitting together again!
Does any one know if the early type crank shaft sensors leak oil!!?...I have the rounded type!..the type that looks like its a plug at the SUMP but comes out whole when removed!
       There's is a seeping of oil coming from that area...but it ain't the cam cover gaskets..that was another leak all together! But when I looked at the sensor and sump area...seems to me they fail because at the very least they seep out oil!?!
Anyway...at certain points in journeys the management light will go out...or take a while before it comes on!...(Happens when I take it to high revs/ sport!)...and of course the only codes that came up before were crank sensor and Immobilizer fault codes!
     So for sure a paper clip test again when it's running!
iOmega
  • luton
« Reply #6 on: 08 January 2010, 13:02:08 »
OMEGA KING....sori..my apologies...there's ladies in here too....hello Ladies....and Gents
peter19730
  • manchester
« Reply #7 on: 08 January 2010, 13:06:11 »
welcome to oof
Ken L
  • Sheffield, South Yorkshire
« Reply #8 on: 08 January 2010, 13:21:57 »
Welcome to the forum Nathan, I'm sure someone will be along soon to give you the info you need and maybe some hands on help.
« Reply #9 on: 08 January 2010, 13:23:26 »
Welcome along N :y :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #10 on: 08 January 2010, 13:28:34 »
Welcome to OOF and the best site to help you with probs. Post in the General Help for more info :y :y :y.
« Last Edit: 08 January 2010, 13:29:09 by ci643215 »
« Reply #11 on: 08 January 2010, 13:40:10 »
Hi, welcome to the forum.  :)
R.C. ™
  • Surrey . England
  • R.C. 本傑明 ™
« Reply #12 on: 08 January 2010, 14:01:45 »
Welcome to the forum Nathan  :y
No illusions , No spin , No quick fixes , No compromises , No limit to how far you can go - Get an Omega
« Reply #13 on: 08 January 2010, 14:13:17 »
Welcome to OOF mate :y
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #14 on: 08 January 2010, 14:32:50 »
hello and welcome :y
v6 cam locking kit  member:y
