Author Topic: Two Cateras and a change of plans  (Read 7566 times)
Doug Chase
  • Seattle area, USA
« on: 05 December 2010, 22:47:41 »
Hi All,
I thought I'd drop in and introduce myself since I've been surfing around here learning stuff for a while.  Looks like a good forum so far, and I'm happy to have found it.
At the beginning of June this year I bought two '97 Cadillac Cateras.  I got a gold one with 67k miles and a dead engine, and a black one with 134k miles and a dead transmission.  Both are very good cosmetically and both had leather interior.  I planned to fix them both, keep the black one, and sell the gold one.
I rebuilt the transmission in the black one and drove it for several months and several thousand miles, then two weeks ago it slid off the road during a teenage snow driving lesson.  Oops.  It doesn't have much mechanical damage from this, but the whole left side of the car is wrinkled up.
I recently started working on the gold car.  The previous owner said it came to him with a bad head gasket, and it also had low oil pressure, and then it had developed a cranks but won't start condition.  When I got the car it would crank forever without starting and the cranking sounded a little uneven.  The other day, before a real compression test, I did a "crank and listen for unevenness" check.  After cranking for about two seconds and thinking to myself, "this doesn't sound uneven at all", the car started!  Odd, indeed.
It has a bit of a knock and I currently believe this to be a connecting rod.  It also appears that a previous owner has bypassed the oil cooler by cutting off the lines right above the oil filter and looping a piece of rubber hose between them.  This leaks pretty significantly when the car is running.  I have a feeling that I'm going to discover more and more the farther I dig into this motor.
That brings me to the change of plans.  I believe at this point I'm going to transplant in the motor (and freshly rebuilt trans) from the black car, then sell or part out the black car.
So that's my story so far.  I'll be asking some more specific questions about the engine swap, but wanted to drop in here and introduce myself first.
Doug
Doug Chase
http://www.ChaseRace.com
Duvall, Washington, USA
Re: Two Cateras and a change of plans
« Reply #1 on: 05 December 2010, 22:49:57 »
How do you Doug, welcome along.  :y :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2 on: 05 December 2010, 23:26:17 »
welcome to the forum doug :y, a bit of an oops with the off roading eh. :o
Doug Chase
  • Seattle area, USA
« Reply #3 on: 06 December 2010, 03:10:04 »
Yep, that wasn't quite the intended path of travel.  Oh well, lessons learned all around.
Thanks for the welcomes, both of you!
Doug Chase
smithpa7
« Reply #4 on: 06 December 2010, 07:32:28 »
Hello Doug, welcome to the forum :y :y
    • E250 Est / Elroq
« Reply #5 on: 06 December 2010, 07:35:52 »
Hello & Welcome  :y
Welung666
« Reply #6 on: 06 December 2010, 08:05:39 »
Welcome to OOF Doug :y
Omega_Dan
« Reply #7 on: 06 December 2010, 08:15:39 »
A warm welcome to you Doug :y
« Reply #8 on: 06 December 2010, 08:35:13 »
Welcome to OOF mate  :y
2woody
  • Northumberland
« Reply #9 on: 06 December 2010, 08:58:06 »
which bit of Washington ?  - one of my favourite places
and welcome by the way
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #10 on: 06 December 2010, 09:08:33 »
Welcome bud! :y
Kneepad
  • West Scotland
« Reply #11 on: 06 December 2010, 09:10:00 »
Hello Doug, welcome to the forum.    :y
« Reply #12 on: 06 December 2010, 09:38:17 »
Hello Doug and a warm welcome to you! :y
Elitenut
  • Redditch, Worcestershire
« Reply #13 on: 06 December 2010, 10:30:40 »
Hello and welcome to the Forum. :y
Jusme
  • North Hykeham, Lincoln.
    • Lexus LS430
« Reply #14 on: 06 December 2010, 10:46:42 »
Hi Doug, and a warm Welcome to the OOF..  ;)
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
