Author Topic: Front door loom connector  (Read 13261 times)
Martin_1962
Re: Front door loom connector
« Reply #15 on: 12 July 2006, 16:16:29 »
The tweeter and bass driver use seperate cables into the door, when I did my CD2.0 I didn't find where they were joined
nixoro
  • Hitchin, Herts
« Reply #16 on: 13 July 2006, 08:39:00 »
I think this maybe the difference facelift or pre facelift, only my omega 97P the tweeter cable looked to be seperate from the bass speaker cable when I was last inside the door removing my clicking check strap.
HTH
« Reply #17 on: 15 July 2006, 11:03:01 »
Right, I sort of gave up on that connector, and yet again, sort of put the job off, as it was working ok again.
This morning, its playing up again. I turned the balance/fader purely to drivers front speaker, and only getting a quiet muffle from it (with intermittent bouts of working properly). Both speaker and tweeter were almost silent.
From previous posts, does this rule out speaker and that connector. Where should I look next?
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #18 on: 15 July 2006, 14:31:49 »
from what I remember on my pre-facelift when I was trying to find out what had been done to the bose amplifier, there is a multi-way connector under the driver's side kick panel too which has all the speaker connections on it. Might be worth reseating that one as well but as it doesn't normally get touched, I wouldn't have thought this would be the problem ...
