Author Topic: Oil overfill HELP!!!  (Read 11156 times)
Tony H
  • liverpool
  • Black Elites are luurvley
« on: 23 July 2006, 21:53:51 »
Out driving yersterday I hit the go peddle to overtake looked out of the rear view mirror only to see a huge cloud of blue smoke belching out of my exaust, it was that thick that I could hardly see the car that I had just overtaken. It transpires that my other half had (under the advice of the man at the garage) put 5 ltres of 10W40 magnatec oil in it.after check oil level came up on the MID. The car has travelled about 150 miles in this condition any advice please on what to do?apart from drop the oil out of it change the filter and top up with correct fluid and I hope you can answer the question is there likely to be any permanent damage,no
Re: Oil overfill HELP!!!
« Reply #1 on: 23 July 2006, 21:59:48 »
Do it as soon as possible - its possible to damage seals (even pistons in extreme cases)...
dRjENSEN
  • Nysted, Denmark
« Reply #2 on: 23 July 2006, 22:12:49 »
Maybe the wife just got it a tad wrong, as 5 ltrs is what a complete oilchange with oilfilter takes..  ;) (on the 2.0i 16v anyways)..
Opel Omega 2.0i 16v (12/1997)
« Reply #3 on: 23 July 2006, 22:13:38 »
2.0/2.2 is 4.5l, v6 is 5.5 l
dRjENSEN
  • Nysted, Denmark
« Reply #4 on: 23 July 2006, 22:15:31 »
Nope.. 2.0i is 5 ltr if you change the oilfilter too (and we allways do, don't we!)
« Reply #5 on: 23 July 2006, 22:17:50 »
Yes, you're probably right - I did a 2.2 yesterday and it took 4.5l, but I filled oil filter before I put it on and started measuring what went it, so its 4.5l plus whatever the filter holds :)
RonaldMcBurger
« Reply #6 on: 23 July 2006, 22:36:01 »
Go and see the numpty in the garage and slap him silly. >:(
Tony H
  • liverpool
« Reply #7 on: 23 July 2006, 23:35:05 »
Its a 2.5 lump the oil level was about 4 inches above the max line on the dipstick :'(
« Reply #8 on: 24 July 2006, 00:18:22 »
Was this drained first? If not you could have 10 litres of oil in there!! :o
Get it drained and changed ASAP!!
I am working on a oil change guide at the moment (just need to take a better picture of the sump plug, and it will be ready)
cipher
  • Derby
« Reply #9 on: 24 July 2006, 00:42:59 »
too much oil can be more damaging than not enough in some cases
Breaking a 1996 'N' 2.5 V6 Omega
PM For Details
« Reply #10 on: 24 July 2006, 08:31:44 »
Blimey!  Sort it immediately before something gets damaged!
nixoro
  • Hitchin, Herts
« Reply #11 on: 24 July 2006, 08:53:49 »
Did the guy actually check the oil on the dipstick in the garage or was it the wife.
If the garage didn't do the proper checks I would go back and complain.
Hopefully there isn't any major damage.
Taxi_Driver
« Reply #12 on: 25 July 2006, 07:37:29 »
Now I dont know if this is the case with Omegas and i'm sure an expert will advise. But i always thought if seriously too much oil.....which i would have thought 10litres is  :o apart from other damage that may happen.....the oil can spill over into the gearbox....so a gearbox oil change maybe in order.
Anybody know?? Or is this just on manuals? Dunno.....I heard it somewhere tho :-/
PS Why hasnt Omegas got an 'Oil level too high' warning.......its got sensors for everything else!!
RonaldMcBurger
« Reply #13 on: 25 July 2006, 08:04:49 »
The oil cannot get into the gearbox, they are two seperate sealed units. It is feasible that itcould be so bad it spill into the clutch though.
Basically too much oil means no crankcase air space, and that can cause serious damage as the pistons are effectively trying to compress oil instead of moving air.
I suspect you may have some serious damage mate. At the least, several oil seals and gaskets will have suffered. I stioll say slapping th garage man silly is the best way forward.
« Reply #14 on: 25 July 2006, 10:04:19 »
Give it to Mr McB for a day or so, hes very good with cars that have/require oil leaks... ;)
