Author Topic: Climate control query  (Read 2383 times)
rob114
« on: 13 August 2006, 22:22:28 »
Hey!
This problem got 'mulled' over on the 'other' :-[ site but need some more advice!
The problem is this: Aircon works fine-nice n cold! However,when I needed some heat back when I bought the car in march, it would only come when the CC was set to max. Not a problem at the minute but shortly will be due to harsh winters in the North East!
The general consensus was a faulty fan blowing air across the sensor for the CC (already tried hoovering it/reseting etc) as it would not hold a piece of paper acroos the sensor vent.
So,some guys say they soldered a new fan on with varying results,some replaced the unit,some did b*gger all!
Would a secondhand CC unit be the ideal fix? Bit confused as to what this actually is - seen a new CC fascia on ebay with all the dials & Sensor - is this all there is 2 it?    :o
Any fix would involve removing the unit-any tips?
Cheers
Re: Climate control query
« Reply #1 on: 14 August 2006, 08:36:33 »
The cc control panel is a self contained unit and do appear on ebay from time to time......I also have a spare fan if its of any use (4 soldered connections).
rob114
« Reply #2 on: 14 August 2006, 10:09:26 »
Thanks Mark - there are a couple on e-bay now but quite expensive!! Will try the fan route first - will pm u about the fan
Thanks
