Author Topic: Paperclip test  (Read 1439 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Paperclip test
« on: 05 September 2007, 21:05:31 »
Just pondering after reading another post about the paperclip test, could the useless trafficmaster button be rewired to the back of pins 4&6 of the diag socket to give a test button?
My thinking is its a push to make switch so would just need to be held in to activate the test.
I seem to recall when I had the radio out i disconnected a trafficmaster adapter loom with a couple of wires leading up towards the button so these should be fine.
So how do I get behind the fuse panel to connect, easy job or half the interior out to do it?
Hmmm might have a play tomorrow, Jaime is always telling people to run a paperclip test regularly.
This would make it simple, and finally find a use for that stupid button.
Anyone see any reason not to try this?
TuBy's new whipping boy.
    • 530D M Sport, 330i Coupe
Re: Paperclip test
« Reply #1 on: 05 September 2007, 21:26:52 »
...the button will be worn out in a month!!!!!
STMO123
Re: Paperclip test
« Reply #2 on: 05 September 2007, 22:50:32 »
Good idea. But I just wouldn't fancy having two pins in the diagnostic socket shorted out all the time. Especially as its only a two minute job anyway :-/
Now, if you could get Mrs Robot to read out the fault codes, that would be neat :y
« Last Edit: 05 September 2007, 22:52:12 by STMO123 »
Re: Paperclip test
« Reply #3 on: 05 September 2007, 22:57:59 »
Make her do both...... 'You are near M40 Southbound, severe delay, avoid oh and your crank sensor is stuffed so your going nowhere anyway'
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: Paperclip test
« Reply #4 on: 05 September 2007, 22:59:03 »
 ;D ;D ;D
[size=24]        [/size][/b]
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Paperclip test
« Reply #5 on: 05 September 2007, 23:01:20 »
Won't be shorted out all the time if its put through a push to make switch, only when you push it like a door bell does.
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Paperclip test
« Reply #6 on: 05 September 2007, 23:05:38 »
Got one of them
SWMBO.. :D
Is the world ready for me..
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Paperclip test
« Reply #7 on: 05 September 2007, 23:07:31 »
Got one of them
SWMBO.. :D
Your swmbo is good with directions!?!?!?
You must have got a top of the range model  ;D
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Paperclip test
« Reply #8 on: 05 September 2007, 23:09:26 »
Got one of them
SWMBO.. :D
She don"t miss a thing   :o
