Compression Testing V6
Started by Allenm, 22 August 2006, 11:29:14
Allenm
well that took ages to get the f'ing plug out of 6!!  does it matter that the engine is now nearly cold and how do these damn relays come out????
Quotewell that took ages to get the f'ing plug out of 6!!  does it matter that the engine is now nearly cold and how do these damn relays come out????
Just be thankfull it's V6 and not a C30SE straight 6 - that really is a PITA to get out.
Allenm
v6man54deg              Geffd
bit late i know but best to take all 6 plugs out and also to unplug the crankspeed sensor - that way you get no spark or fuel injection, the fuel pump relays are quite tight / hard to remove.
QuoteTest done..  result posted back in the original thread, here
http://www.omegaowners.com/forum/YaBB.pl?num=1153140766/220#220
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
