Whats this for / do??
Started by tunnie, 25 August 2006, 14:13:21
Found this dangling on Project B, comes down near the oil filter & emmisons sensor on the exhaust:
Yes my hands and arm is too clean, only just got up!!  ::)
nixoro
#1
Looks like a speed sensor to me
interesting, can't see where its supposed to clip on to or meant to be  :-/
nixoro
Just been looking again at the piccy is it coming from the engine or is it near the inside of the wheel.
nixoro
Forget that Idea it looks like its too far away from the road wheel to be a speed sensor.
Not sure what it could be
Admin
#5
 ;D
That's a crank sensor!  :)
It has obviously been replaced and they didn't remove the old one.
It sits next to the oil filter
Edit: And when did that last have an oil and filter change?
That is certainly not a Vx filter!  ;)
The Administrator.
Matchless
Thats a crank sensor. Fits into a hole just below and slightly right of the oil filter. If there is one already fitted there then the old one died but was left hanging because its impossible to separate the wiring from the oil cooler pipes and exhaust without x-ray vision and several additional joints inserted into the forearm.
Matchless
Dave's obviously had more practice at typing
Admin
The Administrator.
nixoro
#9
Quote;D
I was so tempted to say crank sensor but I wasn't sure what they looked like on the V6  ;D
Some expert hey  ;D
Yup, crank sensor - remember I said to you it had been changed, and was routed via the abs unit, rather than down back of engine...
Auto Addict
Fancy not knowing what that was tunnie, and you an expert as well ;D ;D
I like red cars
QuoteYup, crank sensor - remember I said to you it had been changed, and was routed via the abs unit, rather than down back of engine...
Ahh ok, sorry. Again some expert huh?
Just topped the oil up (was on the min stop) & gave the ICV another clean, and took the car for a bit of a run. - Its definetly quiter than before now, when i got it back, i reved the engine with the bonnet up. It seams much much quieter now, although there is still a ticking noise on idle.
If i held the gas pedal at say 1,800 rpm or 2,500 rpm the engine sounds sweet as a nut. No tapping noise what so ever, it seams to be between idle and about 1,500 rpm its at its loudest.
Again got a bit of long wood, and poked it all around the heat shield on the passenger side. Although its loose to pull up, pinning it down with something did't affect its sound  :(
Tempted to go down to ATS, and get "quote" on the problem.
rpont
If it was the manifold gasket I wouldn't expect it to go quiet at higher revs then start again when it went back to idle. It might stop as it warmed up but I still wouldn't expect it to start again at idle.
If this is the '95 car I think it would be lifters. My '97 2.5 had three duff lifters at the front drivers side exhaust that wouldn't hold their pressure at idle.
I've got 21 good old style lifters since I'm replacing all of mine while it's apart. I'd be happy to send you some once mines back together and runing. I'm still waiting for AutoVaux to get me my 4 new 'T' vents, you have to use the new style vents with new style lifters, so I don't know when they will be available yet.
