Just a quick update....
Started by Tezray, 16 July 2006, 21:36:40
Tezray
#15
*QUICK QUESTION!*
Is it right that my no.3 and no.6 piston appear to be at the top of their stroke? And the others appear to be at the bottom? It's supposed to be set at 60 degree's BTDC  :-?
Tezray
4 Valves done, only 20 to go!  ;D
It would be going a lot quicker, but getting the time is a bit difficult at the moment......Got my headgasket set through now and also my new oil cooler. So once the valves are done, they're going off to be skimmed and then i'll be building it all back up  :)
STMO123
Keep at it mate, you will really feel a sense of acheivement when its done. Wish I had the know-how and the balls to tackle something that big. Good luck [smiley=thumbsup.gif]
Tezray
Thanks mate  ;)
Need a bit of advice now though.....If i cant get this valve cleaner than this by using 600 grit paper, should I;
A.) Use something more heavy duty, e.g. 200 grit paper or a file lol
B.) Re-seat it and be happy with it
c.) Replace the valve
Here's the valve in question and by the looks of it i may have a few like this;
At the moment i'm thinking of using something more heavy duty.....
Tezray
Sorted! Thanks to James' (Vectrolysis) top notch advice  :)
Just used 600 grit with warm soapy water and its now got a mirror finish! lol
Exactly, do the faces and rears......much easier if you put them in a drill clamped in a vice or have access to a pillar drill....
Tezray
Well i finished off the drivers head the other day and it looks like this;
I also slightly polished the exhaust ports;
And made sure the inlet ports were nice and clean;
Admittedly this is taking me ages! Mainly because i have a lot going on at the moment. I want to set aside a solid day to do the passenger head and i think i can have it finished in a day. I serioulsy cannot wait to get the meega back on the road  :(
nixoro
Tezray looks to me your doing a grand job
Looks very impressive what you have done so far.
Keep up the good work
Roy
Tezray
Cheers Roy  ;)
I'm getting much quicker at doing each valve now, it's getting the collets back on that is a complete a-hole sometimes lol And i'm not a vary patient person!
Should be good once the engines all back up and together again. Touch wood i should have a fair few miles of trouble free motoring....Once it's rebuilt it will have had;
-New radiator
-Crank sensor
-Oil cooler
-Thermostat
-Rocker cover, exhaust, head, basically every gasket under the sun!
-Cambelt kit fitted around 2K ago
So let's hope she runs like she's just rolled out the factory  :)
Have you got any pics of your Black omega? I've always wanted a black omega....You don't see them anywhere!
nixoro
QuoteCheers Roy  ;)
Unfortunately I haven't taken pictures of it yet, most of it is now sorted just needs the bodywork tidying up a little and an MOT then its jobs a goodun shall see if I can get some half decent piccys with my phone.
Seen a few black omega's but like you say, not many about.
QuoteCheers Roy  ;)
'Glue' them to the end of a screw driver with a spot of grease, and do the same on to the valve stem.
Markie
QuoteCheers Roy  ;)
Tezray - fantastic work well done so far mate  :)
and as for black omegas mine can be seen here
http://www.omegaowners.com/forum/YaBB.pl?num=1153038412
Looking good.....thats the sort of detailed approach I take to head re-building, clean everything, port it a little, re-fit......remember that if you get any horrible black oily spots or stuck carbon that paint stripper is safe with alloy and very good at getting carbon off.
sounds2k
#28
Quote... I've always wanted a black omega....You don't see them anywhere!
my old one's pictured here - it's in cornwall now though ...
Kev
You're doing a great job there mate. An education for some of us on here.  [smiley=thumbsup.gif]
Hope she fires up first turn of the key.
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
