Just a quick update....
Started by Tezray, 16 July 2006, 21:36:40
Tezray
Ok, i see your point better now! I suppose if, in the future, i wanted the cams done it's no big deal to whip them out and get them done.
I hadn't thought about the lifters and followers until Markjay said, shame really  :(
I'll still have to wait 2 weeks for Grant to get back if i want the heads done though....And then add on the time to do them and the rebuild time. I want my Omega back  :'(
I've called Autovaux and they're getting back to me on a price for a full set of lifters and followers....
Martin_1962
Last time I tuned an engine I took it from 69bhp to 65bhp to 115bhp.
The drop was caused by a rebore using L/C pistons (they supplied wrong ones!!!!).
Twin carbs and Kent cam helped to get it to around 90, VERY heavy head skim (60 thou) to around 100, Hepolite pistons and K&N filters to 115 (silly CR)
Only mild porting!
Easier/cheaper to tune the high torque than locate a sports version.
If I had the money I could have gone bigger on the valves, could have gone DCOEs could have gone wilder on the cam, I have seen a 160bhp version of the same lump!
Tezray
Why would anyone want 1 lifter?  :-? And that 1 looks very slightly different to mine...
Martin, sounds like you've done some impressive tuning yourself! When i had my gsi Nova i bought twin 40's, round port inlet manifold for the 40's, a kent ast2 cam, adjustable fuel pressure regulator, ported and flowef 1.6 head and a couple of other bits.....It's just i never got round to fitting them all!  ;D But when i sold all the bits off again i made a decent profit so it wasn't all bad.
v6man54deg              Geffd
Thats the old style and they have 20 avalable, and thats a cheap price as they are over £10 each to me COST.
the later style fitted to 99 model year V6's has a slimmer piston but you have to fit new style T vents to fit those.
QuoteWhat, like these:
http://cgi.ebay.co.uk/Vauxhall-Valve-Lifter-New_W0QQitemZ300001755517QQihZ020QQcategoryZ10404QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
Markjay
Quote...If I had the money I could have gone bigger on the valves, could have gone DCOEs could have gone wilder on the cam, I have seen a 160bhp version of the same lump!
The intake noise of three 40 or 45 Webers shod with K&N is intoxicating, but I doubt if it will pass the MOT emission test...  ;D
Alas, no more Omegas....
rpont
I got mine from here, £8 each:
http://cgi.ebay.co.uk/Vauxhall-Tappets-Corsa-Astra-Vectra-Omega-Frontera_W0QQitemZ4610101316QQihZ002QQcategoryZ10404QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
As v6man says you need to change the 'T' vents if you go from old style to new style and Autovaux have been trying to get me 4 since the beginning of July. I don't think many people realise that you have to change the vents for the new style lifters...
Martin_1962
QuoteWhy would anyone want 1 lifter?  :-? And that 1 looks very slightly different to mine...
Started as a £100 banger when I was desperate, got offered a 1.6 Avenger lump so swapped out the imp engine, upgraded the suspension. Then I started tuning very little was original in the end - scrap yards were so usefull. I bought Weller 8 spoke wheels for it.
Martin_1962
This was on my Sunbeam - that had 2x 1.5" Strombergs
Tezray
Tbh guys, i'm considering just rebuilding her as she is. I'm not sure i want all this hassle with (what should be) my day-to-day car. Everything is ready and waiting sat in my garage, it's not as though she's slow as she is and a chip, remap and xe flywheel she see her shifting pretty well....
Tezray
Well, i'm afraid i went for the rebuild! I have my reasons....Sorry if anyone was looking forward to seeing the results of the mentioned mods. Anyway, got loads done today! The heads are back on, rear connections sorted, wiring tidyed up, rear cambelt cover on, spark plugs in, PAS pump back on and oil dipstick fitted. I also got my new oil cooler and thermostat fitted. So tomorrow will consist of torquing the heads (new a torque angle guage), fitting the water pump+pulley, crank pulley and re-fitting the cams. Then it's time to get it timed up! I can't believe how much ground i've covered today, its gone so much quicker than the strip down! Pics (sorry about the poor quality);
New drivers head gasket;
Drivers head re-fitted;
Heads re-fitted with gaskets;
The biggest pain in the ar5e today was fitting the engine lift bracket, oil dipstick and steal coolant pipe, what a bastard!!
Auto Addict
Well done, you'll soon be an RMB [smiley=beer.gif]
I like red cars
v6man54deg              Geffd
You shoud have fitted the inlet coolant pipe before you put the passenger side head on - remember how hard it was to get off!!!!!
That outlet pipe is a pain - thats why you often see Omega's without the lifting BKT fitted - I find it easier using a 10mm ratchet ring spanner on the E12 bolt there should be a spacer ring aswell - this was used as the bolt was too long for the hole.
QuoteWell, i'm afraid i went for the rebuild! I have my reasons....Sorry if anyone was looking forward to seeing the results of the mentioned mods. Anyway, got loads done today! The heads are back on, rear connections sorted, wiring tidyed up, rear cambelt cover on, spark plugs in, PAS pump back on and oil dipstick fitted. I also got my new oil cooler and thermostat fitted. So tomorrow will consist of torquing the heads (new a torque angle guage), fitting the water pump+pulley, crank pulley and re-fitting the cams. Then it's time to get it timed up! I can't believe how much ground i've covered today, its gone so much quicker than the strip down! Pics (sorry about the poor quality);
nixoro
Well done Tezray your on a roll now just hope it sounds like new when turning the key for the first time after the rebuild, fingers crossed for you mate  :)
Re-builds are always more pleasent as you are generaly working with nice clean bits....
