Author Topic: Dexron II or III?  (Read 3566 times)
Dexron II or III?
« on: 04 September 2006, 14:47:21 »
I think I know what the answer will be before I ask but ....
Vx's TIS (at the dealers  :) ) says that the gearbox oil - 3.0 auto Elite - should beDexron III 90 510 269 however when you then turn to EPC it says that this part number has been superceded by 90 350 342 which is Dexron II  :-/ So if I change the fluid in the gearbox am I putting in the proper Dexron III from Partco etc or do I put in Vx's superceded part no. & put Dexron II in?
PS After dropping the sump pan and removing 4.4 litres (probably from my drive! :-[ ) what about the remainder in the torque converter?
Markjay
  • London
Re: Dexron II or III?
« Reply #1 on: 04 September 2006, 14:57:46 »
Not sure about the Vx P/Ns, but the auto gearbox if definately Dexron III, not II.
The Power Steering however, uses Dexron II, not III - apparently Vx tried using Dexron III for the PAS but it was causing leaks so they downgraded it back to Dexron II.
Incidentally, the general view here is that there is no point in getting Vx own-brand ATF - any good quality full-synth Dexron III AFT should do. Vx are apparently quite expensive on this item for some reason.
« Last Edit: 04 September 2006, 14:58:22 by markjay »
Alas, no more Omegas....
Markjay
  • London
« Reply #2 on: 04 September 2006, 14:59:40 »
As for the draining, you drop the main oil pan as well the small one in the front, and that's about it...
There is also a filter which needs to cleaned (or replaced if it is damaged).
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #3 on: 04 September 2006, 15:02:52 »
Huh! You sound suprised that VX would be expensive :o
Markjay
  • London
« Reply #4 on: 04 September 2006, 15:05:04 »
Vx Trade Club prices are VERY cheap on most Vx-brand service items, e.g. engine oil (4-for-the-price-of-3 offer), spark plugs (around £2 each), brake pads (£12), etc....
« Reply #5 on: 04 September 2006, 15:07:56 »
That's handy to know  :)
Partco sell their Dexron III at c£15 for 5 litres, Vx however sell in it 1 litre bottles or a 55 litre barrel!  :o We could do a 6 (wo)man group buy  ;D
mr des
  • limerick, ireland
  • Doh
« Reply #6 on: 04 September 2006, 18:35:10 »
just thought id add that its Dexron III in the manuals too
i want to shine in the eye of orion but i drove my sole through the black hole
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #7 on: 04 September 2006, 18:42:46 »
It also doesn't help that it's not available on Trade Club.  :-?
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
Markjay
  • London
« Reply #8 on: 04 September 2006, 19:42:56 »
True. My Trade Club Vx dealer gives me normal Trade prices for anything that is not on TC, but in this case even so it is too expensive.
