Alternative to the green sealant
Started by evanh, 05 September 2006, 12:59:32
evanh
Is there anything I can use in place of the green vauxhall sealant 90 542 114 , as the dealer here does not have it in stock and will not order it for me, as apparantly it comes in boxes of 10 ?
cheers
Damn, I had some, and threw it away....
Sorry, do not know alternative.
nixoro
If the sealant is needed for rocker cover gaskets the recommended is Black sealant part no- 93165267 the green stuff goes hard and breaks up in time.
evanh
#3
No not for the rocker gaskets, apparently it is needed to install the 1st camshaft bearing cap. Have got the black stuff for the rockers tho   ;)
Allenm
If your local dealer wont order it for you, I would be inclined to give Vauxhall a ring and ask them where to source it from (explaining your dealers position).
Sort of thing often ends with "we will send you a tube as a gesture of goodwill"
Nothing to lose.
JasonH
I'm not sure either of these is exactly right but I recollect Geffd (v6man54deg) recommending loctite 5900 for a few jobs (it's what they used in the plant) I think that it was for the rocker covers, sump and some other things.
JSeaman used Omnifit green sealant for parts of his engine rebuild, but again I I'm not sure about camshaft bearing caps.
Some research on the above may find an answer.
rpont
It was Omnifit for the front camshaft bearing caps. I got some off eBay but had to wait awhile for it to come up.
