Pollen Filter
Started by nixoro, 05 September 2006, 11:33:16
nixoro
Just changed my pollen filter and my car seems to be running like crap now.
Is there a right and a wrong way to put these in should replacing affect the performance.
Maybe a daft question but thought I would ask.
Auto Addict
I thought the pollen filter only affected the air con.
I like red cars
nixoro
My car seems gutless since putting it in dont know why. :(
Martin_1962
You have disturbed something, or it is a coincidence
There is a loom running past it, has anything been dislodged off the back of the engine?
nixoro
QuoteYou have disturbed something, or it is a coincidence
No not as far as I can see, although I shall have a proper look after work.
Cheers Guys :)
Allenm
Its stating the obvious I know, but have you tried taking it back out...?
nixoro
QuoteIts stating the obvious I know, but have you tried taking it back out...?
No just wondering whether there is a right and a wrong way to fit or something silly.
Kev
Sounds like a Vac pipe has been disturbed, especially if it's idling ok, but suffering while under load.  :-/
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
nixoro
QuoteSounds like a Vac pipe has been disturbed, especially if it's idling ok, but suffering while under load.  :-/
I think I may have solved my problem just checked and one of the giant jubilee clips is broken from the air intake where it joins the MAF sensor.
Shall call in at Vx on the way home, and replace to see if this solves the problem.
The car idles fine with no stalling.
That won't help.
Except vac reservoir, there is nothing near pollen filter that would cause any engine probs...
nixoro
#10
QuoteThat won't help.
Been thinking about this myself I would have thought this would only effect the idling and if air was getting out which I am doubting you would have the EML coming up by rights due to it possibly affecting the MAF sensor which doesn't seem the case.
Shall still get the clip as it still needs replacing.
nixoro
Could me putting it in the wrong way around cause problems.
May try turning it around before leaving for home, see if it makes any difference.
Cheers for all the responses
Absolutely not.
It has an arrow on saying air flow direction.
nixoro
QuoteAbsolutely not.
Ok never noticed any arrow  [smiley=embarassed.gif] shall double check its pointing the right way as in inwards or outwards?
TheOutcast
There is no way that the pollen filter can effect engine performance, even if it's fitted the wrong way round.
This is a really stupid question, but here goes, are you confusing the air filter with the pollen filter? See, I told you it was a stupid question. ::)
