Radiator...
Started by Al_Presidente, 21 September 2006, 20:29:26
Al_Presidente
I think I have developed a leak in my radiator, and was hoping that I could solve it using Radweld, as I have done on other cars I've had before.
However, is there no filler cap directly into the radiator? I took the front panel off and there doesn't seem to be a cap to open up?
How would I go about putting radweld in, or would that be a no-no...?
IrmscherKris
i'd only use rad weld as a temp mesure tbh.....
where bouts are you and what engine have you got?
Not a fan of radweld, but I guess it could go in by disconnecting top hose?
Al_Presidente
Quotei'd only use rad weld as a temp mesure tbh.....
It is certainly only a temporary measure, I can't afford a whole new radiator or the time off work at the moment to get it looked at. Its a 2.5 V6 engine.
STMO123
I used to put an egg in, but dont suppose I should do that nowadays either ;D
QuoteI used to put an egg in, but dont suppose I should do that nowadays either ;D
I thought that was an old wives tale? Does it work?
STMO123
It certainly did! The egg wouldn't set until it hit the fresh air ie. the leak. Didn't last long though. My mate( a real tight b*****d, used to go through a dozen eggs a week) ;D
iggy21uk
If your going to use one of those type of products, I think K-Seal is a better product.
Made by Kalimex www.kalimex.co.uk.
You will find it on fleabay
[color=red][size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/color]
Markjay
#8
Sure it does. You push a whole fresh egg with the shell into the expansion tank, warm the engine up to running temperature, then drive around for exactly 3 minutes and it is ready to eat...
Alas, no more Omegas....
STMO123
How do you get it out again?
Markjay
Hmmm.... I'll have to get back to you on this one...  ;D
iggy21uk
Thought you had to be a poacher driving a hatchback running on shell for that to work?
;D ;D
STMO123
;D ;D
Eggsellent ;D ;D
Markjay
;D ;D
Eggsellent ;D ;D
Surely you meant Eggshellent?
iggy21uk
Thats's a cracker, but yoking apart,I  don't want to egg u on, I still
feel K-seal  is better than Barxxxxx.
But it depends on your £££ ?
