Author Topic: Handbrake lever travel  (Read 8717 times)
Paul M
  • Edinburgh
« on: 05 October 2006, 15:37:24 »
Hi guys
What's the normal handbrake travel on your Omegas? Mine seems to be way too high, about 6 or 7 clicks to get a decent bite. I spent ages adjusting it at the wheels a few weeks back, getting it to the point where there's resistance spinning the wheel then backing it off a little. Very little, if any, improvement. In comparison, my BMW has a very similar setup with the drums inside the rear discs, and it holds on a flat with 2 clicks, and is rock solid even on steep hills with 4 clicks.
What's weird is that the Omega doesn't seem to have any adjustment at the handbrake lever itself. On the BMW, you back off the handbrake lever nuts, then adjust at the wheels to get both sides properly set, then readjust the handbrake lever bolts to get the right amount of travel. I couldn't find any adjustment on the Omega other than at the handbrake drums themselves. Is this correct? Surely they haven't been real boneheads and put the adustment under the car? Although going by much of the other design on this car..... hmm
BTW The rear discs, pads and shoes were changed less than a year ago so they're still pretty new.
Bo Bo
  • Coventry
Re: Handbrake lever travel
« Reply #1 on: 05 October 2006, 15:42:17 »
Mine's the same, trouble is when I use other cars I tend to put the handbrake on way to hard thinking they're the same as mine!
« Reply #2 on: 05 October 2006, 15:43:28 »
Its improtant to adjust (any) handbrake in the right order.
You must slacken the hand brake cable off first, this is done by removing the exhaust heatshield to gain access to the handbrake assembly.
Then adjust the rear shoes using the method you mentioned i.e. shoes binding then back off slightly....make sure that all the springs etc are in place including the return spring on the back of the brake shield. Its also important that the mechanisms are working well (see maintenance guide for info).
Then adjust teh hand brake cable to suit.....its important on ANY car that when the hand brake is off that there is slack in the cable (your BMW one may be to tight!).
When set correctly the Omega one should be well on at 6 clicks (its quite a fine ratchet), you can just about get away with 5 clicks but do watch the slack in the cable.
Paul M
  • Edinburgh
« Reply #3 on: 05 October 2006, 16:04:27 »
Hmm seems like a bit of a PITA then, does make me wonder why they couldn't put the adjuster inside the car rather than underneath. On the BMW you just pop off a piece of trim in the centre console and the nuts are easily accessed. I guess it's the same reason GM put the DIS pack round the back of the engine ;)
I guess I'll be living with it for now then. If I ever get round to changing the exhaust I'll probably do it then.
BTW The BMW brakes weren't done by myself, it was a BMW independent specialist who does all the work on my BMW. He knew exactly where to find every nut and adjuster, checked all the cables for free play, oiled the ratchet things etc. All in a very professional mechanic (I've had more complex work done there too) so I'm fully confident he hasn't overtightened the cable. I'd be most happy if my Omega handbrake was half as good! If only some of you more knowledgeable types were closer to me, there could be a nice little earner in sorting all these kind of little niggles on my Omega! :D
Cheers.
Admin
« Reply #4 on: 05 October 2006, 16:04:43 »
To add to this as I changed the handbrake cable and so had to reset the brakes for a friend last weekend...
It is not a difficult job but to do properly you MUST release the handbrake cable so there is not any tension on the cable.
Once you have the back end on axle stands go round all the nuts that hold the heat shields on and spray copious amounts of penetrating fluid on them. Also use the little straw to spray between the shield and the car body.
Leave to soak for 30 mins.
Come back and re-spray then try and undo them.
If you don't do this you will snap them all off as they really rust on!
The hadbrake cable adjuster sits behind the propshaft so access is rather limited.
If you don't have a 13mm ratchet spanner, get one or you will spend half an hour undoing that nut!  >:(
I would also recommend greasing all the exposed areas of the cables.
The Administrator.
« Reply #5 on: 05 October 2006, 16:13:30 »
Fancy doing mine LB? ;)
The Barge Captain
« Reply #6 on: 05 October 2006, 16:16:53 »
Exactly how I did it earlier this week. Still sheared one stud off though >:(
Pain in the arse adjusting the drums though.
Admin
« Reply #7 on: 05 October 2006, 17:26:36 »
If you sheared just one you have done very well! :)
And Jaime... no thanks mate, certainly not one of my favourite jobs!  ;)
The Administrator.
« Reply #8 on: 05 October 2006, 18:09:18 »
Bugger  >:(   ;)
« Reply #9 on: 05 October 2006, 18:11:49 »
Hi guys
What's the normal handbrake travel on your Omegas? Mine seems to be way too high, about 6 or 7 clicks ...........
Just a couple of clicks on mine - [size=14]N[/size] [size=14]R[/size] then [size=14]P[/size]!  ::)
« Reply #10 on: 05 October 2006, 18:13:11 »
Hi guys
I used to do that, until the next MOT when the cable had seized and it failed :(
Paul M
  • Edinburgh
« Reply #11 on: 05 October 2006, 23:23:13 »
Hi guys
LMAO.... the american way! That'll be why someone nearly rolled into me every time we had to stop on one of san francisco's many mammoth hills, slush tronic or not it's gonna roll back unless you use the handbrake :D
BTW How do you manage without cupholders in the Omega?
JasonH
« Reply #12 on: 06 October 2006, 08:15:30 »
The cable adjuster is quite easy to get to really, just drop off one heatshield (something like 4 x 10mm nuts) and you can get to the cable adjuster.
Admin
« Reply #13 on: 06 October 2006, 08:26:58 »
Removing both makes life easier (but increases the chances of shearing one). ;)
Ratchet spanner really makes things easier undoing the adjuster...(relatively speaking!)
The Administrator.
RonaldMcBurger
« Reply #14 on: 06 October 2006, 08:37:38 »
Great guide there Laidback, but you forgot to mention it is best when it is throwing rain down and you can swear a lot doing it. I am surprised you don't want to do Jaimes one! ;D ;D ;D you seemed to enjoy that so much last weekend!
I would add that the car Laidback was working on is one of those cars that you wish you hadn't offered!
