Author Topic: fault codes  (Read 2538 times)
marcbcfc
  • dorset
fault codes
« on: 12 October 2006, 15:26:59 »
Gents
i posted the other day about the fault codes i am getting when i do the paperclip test
they are as follows:
73 air flow sensor low voltage
31 crankshaft sensor- does this come up because engine is not running?
57
135 Would this   come up if a bulb had gone on the dash as i know one of mine has
and also
13 oxygen sensor
can anybody help please :'(
Re: fault codes
« Reply #1 on: 12 October 2006, 15:33:38 »
31 is right for engine not running (as I will prove to Laidback66 this weekend)
Airflow sensor is not uncommon when other probs, but can also be sign of air leak
135 IIRC, is an error related to bulb
So my feeling is check for air leaks (may show up lamda fault as would be lean), and go from there.
Fix dash bulb as well to get rid of that code...
marcbcfc
  • dorset
Re: fault codes
« Reply #2 on: 12 October 2006, 15:44:20 »
Thanks The Boy
 il do that this weekend and il let you know
many thanks for your help :y
Taxi_Driver
Re: fault codes
« Reply #3 on: 12 October 2006, 20:22:21 »
No carnt be right  ;D
Laidback is right.....surely....he has a more spooky avatar!!
Seriously be nice to know....... :y
Strangely tho when i read my codes with cheapo Tech2 i read em engine off, ignition on and it never reports code 31??  maybe it just ignores 31  :-/
Agemo
  • Cleethorpes
  • Insignia
Re: fault codes
« Reply #4 on: 12 October 2006, 21:05:28 »
Yup, try the test after clearing codes & with engine running. You will find it does not show 31.
Re: fault codes
« Reply #5 on: 12 October 2006, 21:18:22 »
In the red corner, we have LB66, says 19 is right. In the blue, is TB, who knows reckons 31 is right.  Seconds away, round 1  ;D
Re: fault codes
« Reply #6 on: 12 October 2006, 21:26:22 »
Ain't you scared TB i mean just look at his avatar  ;)
Re: fault codes
« Reply #7 on: 12 October 2006, 21:29:31 »
Yup, wouldn't you be?  ;D
Re: fault codes
« Reply #8 on: 12 October 2006, 21:37:25 »
Yeah but ur car could run over his avatar maybe  :y
Re: fault codes
« Reply #9 on: 12 October 2006, 22:22:56 »
But his car is bigger than mine...  ...and he has 2 of them...
Actually, that reminds me, I have 2 Omegas as well at the moment  >:(
Admin
Re: fault codes
« Reply #10 on: 13 October 2006, 10:48:18 »
Erm I have 3 actually!  ;)
The Administrator.
Re: fault codes
« Reply #11 on: 13 October 2006, 11:18:25 »
And a scary avatar. You win ;)
