Author Topic: cambelt help - urgent!  (Read 2659 times)
« on: 13 October 2006, 12:49:50 »
Hi Guys
Got a V6 Elite outside and I'm half way through changing the timing belt kit (yes with the right tool)  ;)
However, I have forgotton the torque values - and I've lost my DVD :(
I can't find them on Mark's torque thread either - Please can someone post up the torque values for the tensioner, and the idler rollers in particular.
Cheers
James
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
Re: cambelt help - urgent!
« Reply #1 on: 13 October 2006, 13:04:31 »
Right james this is from the book of lies, okay.
timing belt lower guide pulley bolt 40Nm.
timing belt tensioner pulley/upper guide pulley assembly
Backplate to cylinder head bolts 40Nm
Tensioner pulley Nut 20Nm
Guide pulley bolt 40 Nm
Hope this helps!
« Last Edit: 13 October 2006, 13:05:48 by RossPhim »
RossPhim
    • 2.2 TDCi TXS
« Reply #2 on: 13 October 2006, 13:07:41 »
And
Timing belt cover bolts:
Outer cover 8Nm
Rear cover
  M6 Bolts  8Nm
  M8 threaded stud 10Nm
I think thats your lot.
Give us a shout if you need more.
Allenm
  • Milton Keynes
« Reply #3 on: 13 October 2006, 13:09:24 »
Crank pully               20 Nm
Water pump pully      Stage 1 - 8 Nm
                              Stage 2  - angle tighten a further 30deg
                              Stage 3 -  angle tighten a further 30deg
Power steering pully  Stage 1 - 20 Nm
                              Stage 3 -  angle tighten a further 15deg
Gwilym
  • Bridgwater, Somerset, UK
« Reply #4 on: 13 October 2006, 13:13:34 »
Hi Guys
You are filling me with confidence :o
« Last Edit: 13 October 2006, 13:14:12 by Gwilym »
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
Gwilym
« Reply #5 on: 13 October 2006, 13:15:05 »
Cheers
James
But it is going again  ;D
