Anybody else got a rattle?
Started by Taxi_Driver, 21 October 2006, 08:16:17
Taxi_Driver
I did, until yesterday.  :)
This maybe of some help to sorting out a rattle from the front, hence the post.
I had a rattle when going over bumps coming from the front, could hear it with drivers window open.
I thought it was something loose/worn with the steering or suspension.
So i took it to my local garage, where they put it up in the air and checked the suspension and steering and found nothing wrong.
They asked me to describe the 'rattle', the best I could come up with was, it sounds like stones being shaken in a tin.
Ahhh.....was the answer and out came a hammer  :o
The mechanic then proceeded to whack the chassis with the hammer and I was amazed as small stones dropped from the Omega  :o
Ok maybe not the best way to get them out.....about 4 small stones fell out......but it did the trick....and now im rattleless again  :y
STMO123
They must love you dropping in with your little problems TD ;D
The Barge Captain
Go on - how much did they charge you for that?
zealious
been doing a bit off off-roading in you megga TD? Powerslide the rear wheel beast around some gravel road corners?  ;) ;D
omegaV6CD
#5
QuoteI did, until yesterday.  :)
New droplinks needed.
Ooops, i didn't read all the post lol ;D
road_rescue
PRICELESS!!!!!
might try that with mine...
14lb sledgehammer do the trick?
With sufficient thrust, pigs fly just fine.
Markjay
The hammer won't cure it. You need a new ECU. If you don't believe me then ask vx.  ;D
Alas, no more Omegas....
Auto Addict
....or is it a cam sensor......
I like red cars
Markjay
Quote....or is it a cam sensor......
No, no, there was no Tesco is sight...
QuotePowerslide the rear wheel beast around some gravel road corners?  ;) ;D
:o Can a 2.2 do that?
Taxi_Driver
QuoteGo on - how much did they charge you for that?
Free of charge  ;)
Taxi_Driver
QuoteThey must love you dropping in with your little problems TD ;D
I always get a free cup of coffee too  ;D
Taxi_Driver
Gravel yes......tarmac no  ;)
Or Tunnies 300,000 mile life tyres  ;D
But ssssshhh! Don't tell him I had a bit of 'slippage' from the back end last time I drove it....
