Author Topic: Main beam bulbs ?  (Read 3464 times)
Glenn
  • Oxfordshire
Main beam bulbs ?
« on: 20 October 2006, 10:45:16 »
Anyone tried any alternative bulbs to make the main beam appear as bright as the xenon dipped beam ?
Lots of supposedly xenon bulbs available, are they any good ?
Cheers
Re: Main beam bulbs ?
« Reply #1 on: 20 October 2006, 12:06:17 »
I use Vaux +50's which seem good (made by Osram I think)
JUT
  • Barnet
« Reply #2 on: 22 October 2006, 13:45:14 »
They're probably Osram Silverstars under a different name then - I've got those in main beam and dip, much brighter than standard.
Don't go for "xenon look" bulbs, almost every blue-tinted bulb puts less light on the road, and many are rated at a higher wattage, which you may think means they'd be brighter, but in truth what you get is a bulb that isn't any brighter (because it's painted blue) and runs much hotter, burning out in a tenth of the time and sometimes taking your wiring with it. Same can be true using 80 or 100w normal bulbs, they draw more current and burn out a lot quicker.
Stick to normal colour bulbs, but in a 30% or 50% uprated brightness. By brand name they'd be Osram Silverstar (best ones in my experience), Ring Ultra Xenon and Philips Vision Plus. All much of a muchness, won't get you that HID-look but will make you lights better.
    • E250 Est / Elroq
« Reply #3 on: 22 October 2006, 16:22:29 »
I use Halfords +50's (Ultra Brilliance I think) in the Mazda, big improvement, and noticed they are on bogof at the moment as well.
« Last Edit: 22 October 2006, 16:22:59 by jimbob »
infinity1
  • sunny south east
« Reply #4 on: 22 October 2006, 17:34:44 »
just a quick one do i need h7 bulbs on my pre facelift?????? why oh why are they twice the price..... :-[
mechanics? not me at all mate...
JUT
  • Barnet
« Reply #5 on: 22 October 2006, 17:37:09 »
I would assume mine's a pre facelift (it's P reg) and it has H1's on main and dips
Taxi_Driver
« Reply #6 on: 22 October 2006, 17:44:49 »
Ive got +50's in my main and dipped beam.......to see the difference......change one bulb first and switch on lights......you can easily spot the extra brightness  :y
rpont
  • Tadcaster
« Reply #7 on: 22 October 2006, 18:18:55 »
I got powerbulbs +50%, bogof + a free set of Philips sidelight bulbs. The sidelight bulbs have a blue coating but I'm not too worried about that on sidelights.
http://www.powerbulbs.co.uk/
I haven't put them in yet but people were saying how good they were on the uk car maintenance group a couple of years ago when they came out.
« Reply #8 on: 22 October 2006, 23:26:21 »
my main beams are excellent, dipped is ok nothing special but does the job.
« Reply #9 on: 23 October 2006, 09:13:35 »
What bulbs you using? If you're not using the +50 type, I would recommend you try a set in your dipped...
The Barge Captain
« Reply #10 on: 23 October 2006, 13:08:43 »
I bought a set of brighter xenon type lamps (standard wattage blue tint) from e-bay - what a load of rubbish >:(
With lights on hi beam they were just about as bright as standard ones on dipped.
« Reply #11 on: 23 October 2006, 13:13:46 »
'Xenon' halogen bulbs are crap, worse than standard halogens, despite what any seller may try to tell you...
The Barge Captain
« Reply #12 on: 24 October 2006, 00:20:33 »
Yep - know that now :(
Still, looked quite cool in a blue kind of way.
