How do you flush window washer system?
Started by Gwilym, 29 October 2006, 21:09:56
Gwilym
As per title.
When I squirt the window whatever is in there really smells horrible.
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
You could remove the washer bottle and clean it out
Personally though, I'd just shove a running hose in the washer bottle, let it overflow and leave it running for a bit
Then top back up with a decent mix of screenwash :)
Gwilym
QuoteYou could remove the washer bottle and clean it out
Cheers mate. Another reason to flood outside my workshop and use my company water!!
On another note, my air con was all sorted and whilst the engine bay had some space to work I treated myself to a brand spanking new radiator so no leaks or anything now.
Engine management light still flickers occasionaly. Visit to Vauxhall - £35 from my wallet and tech 2 says knock sensor faulty. Nice!
Gwilym
QuoteWhich knock sensor matey?
Now now James! You know I don't know about things like that!! That would require some mechanical knowledge
The one on the left? maybe? does that help?
I could point to it but as I don't know where the other one is I am none the wiser
One for each bank of cylinders. No2 is passenger side, and it will be damaged cable where its got trapped near cam cover ;)
Gwilym
QuoteOne for each bank of cylinders. No2 is passenger side, and it will be damaged cable where its got trapped near cam cover ;)
That sounds about right! The guy at vauxhall said something about a pinched cable.
Gwilym
#7
On second thoughts
When you face the car, it is the one that goes behind the cam cover on the left hand side. Wouldn't that be the drivers one then?
QuoteOn second thoughts
that one normally goes around the cambelt cover, but could still be pinched somewhere. The passenger one frequently gets pinched under cam cover...
Gwilym
URGENT MESSAGE FOR JAMESV6CDX
James, you know how much you enjoyed your drive down to Highbridge :y
I would repair the the wire rather than replace the sensor (bit fiddly to get to)
We (I) may well have unplugged this whilst doing the cambelt change....
Check it's connector and wire :)
Passnger side plugs in on cable tray, drivers either on egr bracket or just in front of cambelt cover...
Gwilym
QuoteWe (I) may well have unplugged this whilst doing the cambelt change....
How?
check that the wire coming from the front driver side of the cam cover cable tray is not broken, and that the connector in this location is seated properly...
