Strange OR what !
Started by mar892ree, 29 October 2006, 16:14:40
mar892ree
Helloooooooooo !!!
OK reverting back to the " oil level" thread the other day !
It was confrimed , by members on here, that the 4 pot Omegas take 4.5L of engine ( with filter change) as per the written data in the users manual !
OK , serviced the Omega this morning. drained oil, new filter etc, and 4.5 L ONLY comes half way up dipstick !
As we know between min and max on dipstick is 1L, then i was 1/2 L short !
Got 5L in it and its reading MAX on dipstick !
Whats even stranger is i have gone back through the very compreshensive service records of the car ( all nine of them ) all except one service receipt shows 10 units of oil used ( 1 unit = 1/2L ), the odd one shows 9 units ( 9 x 1/2 L = 4.5L )
Urmmmmmmmmmmmm anyone else !!!!
Engine is a Y22XE ( if that makes any difference ) !
I'm convinced somethings a miss here  :-/
Cheers
Mark
I'm fairly certain we only put 4.5l in Tunnies' 2.2, hopefully he can confirm that though, as I've slept many times since then.....
mar892ree
I'm sure you did Jamie, as Tunnie replied to the other post ( Oil Level) saying 4.5 L inc oil filter change !
But to reitterate ( ohhhhhhhhhh BIG word LLOLL ) 4.5L comes halfway up my dipstick, and also the service records of my car confirm that 5L ( or 10 units ) was used in previous oil changes apart from one which shows 9 x units = 4.5 L !!!
How odd !!!! :o
Maybe different sump or something like that? Or wrong dipstick?
mar892ree
VERY much doubt it Jamie !
The car was a one owner before i had it, and EVERY receipt for work done on it is with the car !
QuoteVERY much doubt it Jamie !
Well something is different. Dipstick is probably most likely I reckon...
mar892ree
OK just found out that there are two different sump pans, and two different dipsticks !
Mainly the difference is between multi function display cars and non multi function display cars !
As Tunnies and TD's cars are both CDX's and mine is a GLS , maybe a possible answer !
Anyone else with a 2.2 GLS !!!!
Mark
QuoteOK just found out that there are two different sump pans, and two different dipsticks !
Mark
Tunnie's is a CD, but that would still have a full MID IIRC...  ...I guess yours has a TID?
Wondering if you have wrong sump/dipstick combination...
Just checked, one dipstick replaces other...
mar892ree
Urmmmmmmmmmmm if the sump pan, dipstick combination is wrong, then it must have been a factory bugger up !
First service has 10 units of oil as being used ? and so on and so forth !
Auto Addict
My 2.2 takes 5L with a filter change!
I like red cars
Auto Addict
If you jack up the front offside slightly with the drain plug out you get another 1/2 to 3/4 of a litre drained out of the sump.
I like red cars
mar892ree
Thank god for that, was beginning to worry !
I must confess the car wasnt exactly on a flat  surface when draining the oil !
I always do mine on a slight slope so oil drains out better !
Cheers for confirming your car takes 5L Auto Addict, i'm not so parranoid now  LLOLL :o
Also manged to drain off 6.5 L of coolant via the tap under the wheel arch, never have got this amount out before ! Just about 5L ish on other changes !
Cheers
Mark  :y
Auto Addict
Mark
No, you obviously didn't drain all of the old oil out.
I like red cars
QuoteNo, you obviously didn't drain all of the old oil out.
Oh, believe me, we went to a lot of effort to get all oil out, as it really was in a state...
