Author Topic: Rear exhaust box  (Read 2523 times)
frenchpolisher
  • Norfolk
Rear exhaust box
« on: 13 November 2006, 12:40:41 »
Morning all, I need to replace the rear box and both middle boxes on my 2.6 V6 (2001). Are they only available from Vauxhall or does anyone know where I can get them? My local exhaust centre only has listing for the 2.5 V6. Would appreciate some help as I really dont want to have to go to the Bandits!!
STMO123
Re: Rear exhaust box
« Reply #1 on: 13 November 2006, 12:49:30 »
While Vx are, as you put it, bandits in some respects, there are times when Vx is best.
Exhausts from Vx are much better than your average "Kwik-fit" rubbish and, whilst they are more expensive, they are worth the extra money ;)
« Reply #2 on: 13 November 2006, 12:57:43 »
On the 2.5/2.6/3.0/3.2 the centre sections are the same.
The back box is the same on 2.5/2.6 as of manufacturing year 2000....
frenchpolisher
  • Norfolk
« Reply #3 on: 13 November 2006, 13:18:13 »
Thanks guys
jonathanh
  • coventry
« Reply #4 on: 13 November 2006, 15:54:49 »
I've fitted Vx parts to mine and can confirm it is as good as new.  Two tips for you
1. make sure you get new centre box to cat bolts - you need 2 for each pipe.  Also when removing the old ones - soak in freeing oil for ages and go very carefully.  They can shear off in the cats.
2. make sure you get a handful of clips that retain the rubber hangers.  you'll surely need a few when you take the old ones off.
Vx dealer may need to order the zorst as they may not carry stock
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #5 on: 13 November 2006, 17:05:28 »
You may need heat to remove the centre box to cat bolts to avoid risking sheering tem
frenchpolisher
  • Norfolk
« Reply #6 on: 13 November 2006, 17:17:19 »
Thanks for all the replies, am having to go with Vx and not go out for the next few months whils't I pay for it!!!
STMO123
« Reply #7 on: 13 November 2006, 17:22:27 »
Well, just to lessen the blow, Tunnie reckons he got 100k out of his Vx exhaust!!!
« Reply #8 on: 13 November 2006, 17:24:18 »
Can you get trade club discount?
Its worth grinding the trhead that protrudes through the back of the cat flange off.....makes the bolt removal a LOT easier.
