Author Topic: xenon headlights  (Read 7462 times)
markey mark
  • SLady bitshorpe north lincs
xenon headlights
« on: 12 November 2006, 16:33:51 »
how easy is it to fit xenon headlights ?? as to wireing ?? only looks like there are 3 extra wires to connect ?? anybody know or have done this !! thanks mark  :y
Re: xenon headlights
« Reply #1 on: 12 November 2006, 16:39:32 »
If you mean HIDs, do a search, covered before. Basically, huge job - headlight washers and HID levelling system required as well as headlights/ballast etc.
markey mark
« Reply #2 on: 12 November 2006, 16:47:27 »
bummer thought you coulnd just fit head lights with ballast packs and rewire them and away you go !!! :(
« Reply #3 on: 12 November 2006, 16:49:15 »
technically, probably. Legally, probably not.
markey mark
« Reply #4 on: 12 November 2006, 16:51:22 »
not too bothered about legally !! but if you were to rewire they would work ??  :y
« Reply #5 on: 12 November 2006, 17:01:05 »
The reason you legally need washing system and headlamp levelling are:
HID lights are adversely affected by slightly dirty lens, far more so than Halogen lights. So HIDs with no washing system (or damaged lenses) will often be poorer than halogen anyway.
Due to the intensity of HID type lighting (in affect, similar technology to camera flashes), a system to ensure that they are never dazzlingly high is required. Not only dazzling, but in very extreme cases can cause retinal damage.
« Reply #6 on: 13 November 2006, 08:57:25 »
From a wiring prespective it should be quite easy (ignoring the self leveling and head light washers).
You would need the connectors from the HID lights to allow it to be plumbed in and from what I can see the level motors from the old lights could be used to replace the self levelling motors.
markey mark
« Reply #7 on: 13 November 2006, 11:06:42 »
cheers mark that was the answer i wanted but missed out on them !!  :'(
JUT
  • Barnet
« Reply #8 on: 13 November 2006, 13:13:01 »
There are ebay seller selling them for £75 quid now anyway - you'd need two H1 sets if you plan to have xenon dips and main beams.
As for headlamp washers - there is no written law on retro-fitting but on new cars they are required. Having had or had use of several cars with them, the washers frankly do very little and aren't worth the hassle - if you wash your car fairly regularly then it'll do a much better job of keeping your headlamps clean than a diddy pressure jet ever could!
(ps you could always just fit Osram Silverstars at c. £20 for 4, have much better lights, with v. little hassle, and be perfectly legal... it's what I did  ;) )
« Reply #9 on: 13 November 2006, 19:02:53 »
The retro fit is currently a grey area.
I would disagree about the washer effectiveness with regards to HIDs.  I drive along thinking that the lights are a bit dim, give them a blast of wash, and lights good again.  HID brightness is so badly affected by even the slightest film of dirt, hence the legal requirement (factory fit) for washing system. Without washing system, decent halogens will probably be equal or better once the lenses get a little dirty...
markey mark
« Reply #10 on: 13 November 2006, 19:37:36 »
dont matter now missed out on them for £2 !! i keep my car very clean anyway  8-)
STMO123
« Reply #11 on: 13 November 2006, 20:28:58 »
Dont know how long you've got till your MOT markie, but, if you fit HIDs and your alignment is out, I doubt whether they'd be able to adjust them for you and they might just call it a fail :question
Salty
  • Fleetwood
« Reply #12 on: 13 November 2006, 21:01:01 »
Has anybody tried the Xenon kits that replace the halogen bulbs? Just wondering if they could be an alternative?
JUT
  • Barnet
« Reply #13 on: 13 November 2006, 23:52:13 »
That's what's being discussed here  :-?
dazzer
« Reply #14 on: 14 November 2006, 00:01:17 »
Just got a 97 2.5 V6.First one i have had.
New here,the cover on my lights look very dull think they are platicts, could i change them for something better ??
Thanks
Dave :question
