Author Topic: Rear window washer  (Read 2591 times)
The Barge Captain
Rear window washer
« on: 14 November 2006, 22:45:52 »
Is there a seperate pump for the rear window wash on an estate? only i'm not getting any water out of mine and i can't hear a pump running (tried with engine off) Wiper starts going though, so i don't think it's a switch problem.
Re: Rear window washer
« Reply #1 on: 15 November 2006, 08:39:12 »
No there isn't, it runs the front washer motor in reverse to operate the rear window washer/stream.
Matchless
  • Nottingham
    • A white van
« Reply #2 on: 15 November 2006, 11:55:44 »
Fair chance that the rear jet is blocked, if it wont clear with a fine wire then get a new one, they arnt expensive.
The Barge Captain
« Reply #3 on: 15 November 2006, 18:58:25 »
Does that mean there are a couple of one way valves in there as well?
« Reply #4 on: 15 November 2006, 19:06:50 »
There will be one way valves in any washer system to stop system 'draining' after use...
Pump has two outlets, depending on roation which one water is ejected from.
