Aux Belt
Started by CaptainZok, 18 November 2006, 21:39:37
CaptainZok
Does anybody have the part no for the aux belt 2.5 v6 with aircon vaux didn't have one in stock and the one sourced from the local factors on the vaux part number is too long.
TuBy's new whipping boy.
BELT, DRIVE, 21.36 X 2260 MM, ALTERNATOR (EXC.JAPAN) (IDENT FJ) (NLS.- USE 9118620 ) (SEE SERVICE INSTRUCTIONS)  X25XE, X30XE  -X1032987 (90448002) (18 54 714) 1
 Note: USED WITH AIR CONDITIONING
BELT, DRIVE, 21.36 X 2020 MM, ALTERNATOR (EXC.JAPAN) (IDENT AC) (NLS.- USE 9118620 ) (EXCEPT VAUXHALL) (SEE SERVICE INSTRUCTIONS)  X25XE, X30XE  -X1032987 (90528761) (18 54 728) 1
BELT, DRIVE, 21.36 X 2020 MM, ALTERNATOR (EXC.JAPAN) (IDENT AC) (NLS.- USE 91126388 ) (FOR VAUXHALL) (SEE SERVICE INSTRUCTIONS)  X25XE, X30XE  -X1032987 (90528761) (18 54 728) 1
BELT, DRIVE, 21.36 X 2260 MM, ALTERNATOR (FOR JAPAN) (IDENT FX) (NLS.- USE 9118620 ) (SEE SERVICE INSTRUCTIONS)  X25XE, X30XE R1000001- S1059678 (90500354) (13 40 615) 1
BELT, DRIVE, 21.36 X 2020 MM, ALTERNATOR (IDENT AC) (USED WITH AIR CONDITIONING) (NLS.- USE 9118620 ) (EXCEPT VAUXHALL)  X25XE, X30XE S1059679- X1032987 (90528761) (18 54 728) 1
BELT, DRIVE, 21.36 X 2020 MM, ALTERNATOR (IDENT AC) (USED WITH AIR CONDITIONING) (NLS.- USE 91126388) (FOR VAUXHALL)  X25XE, X30XE S1059679- X1032987 (90528761) (18 54 728) 1
BELT, DRIVE, 21.36 X 2020 MM, ALTERNATOR (IDENT FD) (USED WITH AIR CONDITIONING) (EXCEPT VAUXHALL) (NLS.- USE 93181720 )  X1032988-  (9118620) (13 40 649) 1
BELT, DRIVE, 21.36 X 2020 MM, ALTERNATOR (IDENT FX) (USED WITH AIR CONDITIONING) (FOR VAUXHALL)  X25XE, Y26SE, X30XE, Y32SE X1032988-  91126388  1
CaptainZok
Cheers for that Jamie looks like my mate at vaux is due a kicking next time i'm in the part no he gave me from their  epc was 90501385. Good job the manager at the motor factors is an old mate too.
