I've cleaned my breather pipes today but..........
Started by Old Sweat-RIPscoob, 18 November 2006, 18:53:59
Old Sweat-RIPscoob
I have spent most of today taking the top parts of the engine apart in order to clean the breather pipes as I know my rocker covers are leaking (next job)
So I read the thread about doing the job a few times before getting started.
In the HOW TO thread it mentioned being careful with the black breather box when removing the ecotec top, but after I removed the four breather pipes off the ecotec bit, undid all the bolts, removed the idle valve, I lifted it off exposing the O rings, I never really came across a black box or a hidden TORX bolt holding the black box to the plenum!!!!!!!!
I have a 2.5 V6 1995, could this be the reason why I don't seem to have this box as my car is older???????
I then followed the four breather pipes down from the ecotec top to a metal compartment between the engine and bulkhead. I pulled all four off and using carb cleaner gave them a good clean, I'm glad I did as there was real sludge everywhere................the previous owner had clearly never done this before so I am worried about the oil/oil filter (which I will also do very soon)
The bigger pipe that splits into two had the most gunk in it................a good tip as mentioned on the HOW TO thread put it on your garden hose as the pressure really cleans it out (and dont point it anywhere near your house!!!!!)
Also I haven't found a pipe with a brass hole in it ?????? as mentioned on the HOW TO thread, the closest thing I found is when pulling off one of the smaller hoses it exposed a brass part that is on the metal box I mentioned earlier, this has a minute hole in it, this was when I used a stiff wire to clean it out.
Next............... what or where is the electrical box? that is mentioned in the HOW TO thread, is it one of the four pipes I have cleaned or is it a seperate pipe somewhere?
Sorry for all the questions, I apologise if I am stupid but this is the first time I have ventured into the engine bay since buying the car, so I am trying to learn as I go.
If Ronald Mcburger is around, the author of the HOW TO thread, thankyou for taking the time to write it originally, hope you can answer my questions :y
Cheers Kevin
I used to have a 400bhp Scoob................I know nothing about Omegas!!!!!!!!!!
Timbuk
' Black Box ' is where the four breather pipes connect
Bo Bo
#2
Quote' Black Box '
Didn't they make "Ride on time"?  :D
I'll get my coat..........
Old Sweat-RIPscoob
Quote' Black Box ' is where the four breather pipes connect
Arrrrrrrrrrrrrrrrrrrrrrrrrrrr [smiley=rolleyes.gif]  mine looks like it is aluminium, I was expecting a black plastic box somewhere, thankyou for clearing that one up :y
Timbuk
Quote' Black Box '
Correct again, and yes get your coat :-?
Timbuk
Sounds like somebody has been playing with it  :-?
Old Sweat-RIPscoob
Quote' Black Box '
I can think of other meanings  [smiley=grin.gif]
And yes get your coat ;)
Chopsdad
Isn't a black box on an aeroplane bright orange?  :-?
Timbuk
QuoteIsn't a black box on an aeroplane bright orange?  :-?
Yes, but this ones on a barge ;)
MikeDundee
But with a slight tinge of Red ;D
Old Sweat-RIPscoob
Can anyone answer my other questions ????????? from my first post ? :'(
Kevin :y
CaptainZok
OK did you remove the plastic bit with ecotec on it from the plenum?
That bit is only a clip on cover, underneath is the hidden torx bolt to remove the bit the four pipes connect to from the body of the plenum so you can clean it.
TuBy's new whipping boy.
QuoteIn the HOW TO thread it mentioned being careful with the black breather box when removing the ecotec top, but after I removed the four breather pipes off the ecotec bit, undid all the bolts, removed the idle valve, I lifted it off exposing the O rings, I never really came across a black box or a hidden TORX bolt holding the black box to the plenum!!!!!!!!
The black box with hidden torx bolt is the black plastic bit on to of plenum with ECOTEC and Griffin symbol on it
Thats the one :y
I'll have to check how2 to check what this is...
no idea what Ronnie means about electrical box  :-/
Old Sweat-RIPscoob
QuoteOK did you remove the plastic bit with ecotec on it from the plenum?
Oh no, I just undid the four bolts and the other side bits, and it all came off,
quite easily actually!!!!!!!!!!!!!!!!!  [smiley=shocked.gif]
Are you going to tell me I've broken the hidden screw under the plastic ecotec bit? :'(
My cars still in pieces tonight. I was going to put it back together again tomorrow, everythings in my garage, so I'll re check the plenum tomorrow,
Thanks for replying
