MOT fail
Started by Salty, 16 November 2006, 15:21:25
Salty
Well just got back from a failed mot :(  although not as bad as it could have been I suppose. Need new front discs, which are an item I think of as consumable so not too bad. Also needs a new steering idler which looks like a trip to the dealer and £60 trimmed from the wallet.
At least I know what I'm doing this weekend ;D
STMO123
Hard luck Salty :( But could've been a LOT worse :)
Salty
What I meant to ask is,
does anybody know if I get the idler for less elsewhere??
Salty
QuoteHard luck Salty :( But could've been a LOT worse :)
Your right there, at least they're fairly easy jobs to tackle.
STMO123
QuoteWhat I meant to ask is,
Have you tried autovaux?
Salty
No not yet, just tried the local dealer
STMO123
Salty
Quote01924 376003
Thanks, works out at about £40 posted not bad :y
Sorry to hear that m8 but could've been worse
nixoro
Sorry to hear of your bad luck salty still atleast its fixable thats the main thing then you'll be good for another year :y
I always tried to keep an idler in garage, as common problem.  As others have said, nice and cheap from autovaux.
Salty
Well I've got the discs and will be doing them this morning if the weather is fine. Ordered the idler from autovaux so hopefully will have that tomorrow.
MikeDundee
QuoteWell I've got the discs and will be doing them this morning if the weather is fine. Ordered the idler from autovaux so hopefully will have that tomorrow.
GM discs I hope, previous set bought not GM had to change as warped >:(
STMO123
Its not GMs fault that your warped ;D
Salty
#14
Well got the discs done today in about an hour and a half :). Idler arrived with the post so decided to do that as well, spent the rest of the day trying to split the old idler from steering arm without sucess >:( will have to have a rethink, may have to take the whole steering linkage off. :o
