Author Topic: Loosing Coolant  (Read 3365 times)
HI2DVY
  • Deepest Darkest, Scotland
Loosing Coolant
« on: 22 November 2006, 00:27:25 »
Took my meega to the stealers a few weeks back to have a service done - couldn't find the time to do it myself.
80,000 miles so cambelt, tensioners and water pump replaced. Cost - £540 (discounted!) :'(.
Since then I notice that I am loosing coolant - about a pint per week (I do about 500-600 miles per week). I've looked all over but can't find where it's going but doesn't seem to be getting into the oil so I guess it may be the pump itself - which I can't see without taking the front end to bits.
First question... I have just been topping up the header tank with tap water and suspect that this can't be healthy long term. I hear a lot of talk about different coolants and additives. Any views on what is the best coolant to use here?
Second question... the car heater/climate control doesnt seem to be heating the car as well as it used to (or maybe just cause it's much colder than it was). Do you think the loss of coolant and the lack of heating may be related? Maybe an air lock?
Any help or suggestions would be very welcome.
Cheers
Dave
some day.....
Admin
Re: Loosing Coolant
« Reply #1 on: 22 November 2006, 08:27:28 »
Take a look at the back of the engine. I suspect the heater bypass valve has failed. This would explain both the loss of coolant and the poor heating.
The heater bypass sits at the back slightly to the left. It has coolant pipes and a vacuum pipe connected to it. Not a difficult job to do, just fiddly. Cost of new valve is around £30, or £230 fitted by your dealer!
The anti freeze most of us use is Vx long life stuff. Around £8 for 5litres (and you will need all of it to get a proper mix.
Oh and £540!!  :o
« Last Edit: 22 November 2006, 08:28:53 by admin »
The Administrator.
Re: Loosing Coolant
« Reply #2 on: 22 November 2006, 09:27:55 »
Did the scumbags change the waterpump?
As LB66 says, HBV is likely, esp with heating problem.
Re: Loosing Coolant
« Reply #3 on: 22 November 2006, 09:30:39 »
I would let it heat up well with the header tank cap removed and keep topping it up to remove airlocks, you need the heaters on FULL whilst doing this.
This will rule out the airlock possability......if after this it still leaks, then check the heater bypass valve etc.....
Note 50:50 antifreeze mix required..... (idealy red antifreeze if thats what has been used to refill the system)
Re: Loosing Coolant
« Reply #4 on: 22 November 2006, 15:25:35 »
 or £230 fitted by your dealer!.........
You're kidding!!!  :-? ...... aren't you??
Admin
Re: Loosing Coolant
« Reply #5 on: 22 November 2006, 16:12:39 »
No!  >:(
Dealer will charge around £50 for the part, £20 for the coolant change and probably around £160 for labour.
The Administrator.
Re: Loosing Coolant
« Reply #6 on: 22 November 2006, 18:34:58 »
No!  >:(
Well! f*** me side ways!  :-?
HI2DVY
Re: Loosing Coolant
« Reply #7 on: 22 November 2006, 23:54:42 »
Hi Guys,
Thanks to all of you for your replies. Excellent advice as always!
I have a bit of spare time tomorrow so I'll check for airlocks etc first and check the HBV for leaks.
I guess at £30 for parts it's probably worth just changing it anyway. Any special tools required? Is there a "how to" on here somewhere?
Dave
some day.....
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Loosing Coolant
« Reply #8 on: 23 November 2006, 00:09:49 »
Don't think there is a HBV guide as yet :( you need to remove wipers and scuttle for access which there is a guide for
http://www.omegaowners.com/forum/YaBB.pl?num=1152710108
some people have suggested removing plenum chamber for greater access still, but you can do it without this. Simple job but a bit fiddley as already mentioned. Once youv'e found it you should be ok. One vac hose on top, two water hoses on the left and one on the right ( looking from front of car towards rear) and its that simple. HTH
HI2DVY
Re: Loosing Coolant
« Reply #9 on: 23 November 2006, 00:35:59 »
Thanks for the info Timbuk. Sound's easy enough. I'll give it a go.
some day.....
Re: Loosing Coolant
« Reply #10 on: 23 November 2006, 09:18:11 »
It is indeed 'easy' but 'fiddly' as access is a bit tight, even with scuttle off...
Page created in 0.032 seconds with 20 queries.
