immobiliser unit
Started by JamesV6CDX, 28 November 2006, 11:21:34
Hi
If I change the ECU on my 2.0, I will need to change over the immobiliser unit apparently,
Can anyone tell me where this is located and what the process is?
Cheers :)
nixoro
Could be wrong but I think its located behind the driver side kick panel.
I'm sure I read it was there but I'm sure someone will be able to confrim wrong/right
HTH :y
Your right, you would be wrong.....!
The immobiliser module is located around the ignition key, dont forget you also need the key transponders.
I know the bugger.... I changed one when doing an ignition barrel
How do you change the key transponders, do they just pop out?
nixoro
QuoteYour right, you would be wrong.....!
Dont know what I was thinking of then  :-[ ;D
Not to worry, I've sussed it...
The transponders can simply be removed from the keys........any news on the window switch and condenser?
QuoteDont know what I was thinking of then  :-[ ;D
ATWS.
STMO123
Hillpers boot mod? ;)
Mark, Pm sent about the bits mate
nixoro
You know thats probably it  [smiley=lolk.gif]
nixoro
ATWS.
Curious what does ATWS mean?
Anti Theft Warning System.......its part of the central door locking ECU where fitted (there are two versions, with and without ATWS)
nixoro
QuoteAnti Theft Warning System.......its part of the central door locking ECU where fitted (there are two versions, with and without ATWS)
Cheers mark I'm no good with abbreviations :-[
