+ 50 bhp and extra 2000 rpm for £5
Started by Matchless, 30 November 2006, 10:57:21
Matchless
Project 2 seemed a bit sluggish and refused to rev above 5k.
Changed the fuel filter last night and now it goes to the red line and seems to be back on song.
Im amazed that a fuel filter had so much of an effect but then Ive never left the same filters in any of my cars for 8 years to find out what happens.
Worth bearing this in mind when buying a car with unknown or dubious service history.
STMO123
Yes indeedy!
Admin
8 yr old fuel filter!  :o
Hmmmm, I almost dare not think what the brake fluid is like then!
The Administrator.
Matchless
Quote8 yr old fuel filter!  :o
Havnt got as far as brake and transmission fluids yet.
Would you like a slice of engine oil?
Admin
Pete, it might be easier to just transplant the engine and transmission from the MV6 (RIP).
It's not like Mark will need it! ;)
The Administrator.
Old Sweat-RIPscoob
Where would I find the fuel filter on my car? :-?
2.5 V6 1995
Reading this has got me worried ;D
Kevin :y
I used to have a 400bhp Scoob................I know nothing about Omegas!!!!!!!!!!
Auto Addict
QuoteWhere would I find the fuel filter on my car? :-?
2.5 V6 1995
Kevin :y
It should be behind the offside rear wheel.
I like red cars
Old Sweat-RIPscoob
By that, do you mean inside the boot area, rather than the actual arch area with the plastic guards :-/
rogerreno
That quote has just brightened up an otherwise long and tiring day!!! Absolutely priceless!!!!!  ;D ;D
Elwood: It's a 106 miles to Chicago. We got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Jake: Hit it!  8-)
Auto Addict
You need to remove the offside rear wheel, it should be under the body where the wheel arch meets the underside of the body.
I like red cars
Bo Bo
I changed mine without removing the wheel  ;) but didn't notice any difference  :-/
Old Sweat-RIPscoob
QuoteI changed mine without removing the wheel  ;) but didn't notice any difference  :-/
Thanks for the replies,
So if I jack up my car, let the wheel hang, I assume I remove the plastic lining and change the filter?????????????????
Is that all there is to it?
Tony H
#12
No need to remove liner the filter is clipped to the bottom of the floor pan. clips can be fiddley to remove and you have to de-pressurise the fuel system first or risk getting a petrol shower I cant remember of hand the fuse number to isolate the fuel pump to do this but i'm sure someone will be along soon to advise :y
Bo Bo
It's fuse 18, see here
The clips are fiddley, but as my filter came with new ones I wasn't bothered about how the old ones came off.
Chopsdad
QuoteIt's fuse 18, see here
Vx clips 49p each - part no 90542453.  AA any chance of a simple maintenance guide - based on a 2.2 like yours would be ideal.  It's the next thing on my tinkering list.  :)
