ECU info
Started by JamesV6CDX, 01 December 2006, 18:16:21
Hi guys
I need to replace the ECU on my project 2.0. I'm sure I've fried it, becaues I'm not getting an EML now. However, someone has taken the sticker off the ECU so I'm not confident about what ECU number I need to get.
I was hoping maybe someone could shed some light - is this info stored anywhere else on the ECU? If not, is there any way I can be sure of what ECU I need to get for this particular car?
It''s an N reg 2.016v
Unfortunately I can't troubleshoot any further until I have a working ECU
Which also means I need immobiliser ignition component and key transponders to accompany, balls.....
Cheers
James
QuoteWhich also means I need immobiliser ignition component and key transponders to accompany, balls.....
And ideally, the immobiliser PIN which is part of carpass from doner...
sure you haven't just blown the bulb?
Pretty sure Jamie, because it won't even try and fire on pots 2 and 3 now....
If I have got the carpasses from the donor, is there any way, that I could just get another key made with them, or is it not that simple?
If you have the immobiliser PIN for the fitted immobiliser, its possible to program transponders to it.
that makes perfect sense Jamie - does anything need to be programmed to the ECU also?
Quotethat makes perfect sense Jamie - does anything need to be programmed to the ECU also?
If the engine ecu and the immobiliser ecu come from same car, then no...
theolodian
QuoteHi guys
Cheers
James
If the ECU works at all, you should be able to get the part # with Tech2.
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
QuoteHi guys
Cheers
James
I don't think JamesV6CDX has a tech2....
theolodian
QuoteHi guys
Cheers
James
Could he send it to you or someone else?
QuoteHi guys
Cheers
James
Nope :(
Sod it, I'm getting fed up to the back teeth of this car now.
I'm going to get another ECU, transponder and immobiliser unit. I'm going to fit the loom off the donor car to rule out any wiring issues.
And if it doesn't go then - it's going to be scrapped.
STMO123
QuoteSod it, I'm getting fed up to the back teeth of this car now.
By which time, it'll have cost you about a zillion quid :o
