Author Topic: High pitched whine on right hand bends  (Read 3871 times)
Gwilym
  • Bridgwater, Somerset, UK
« on: 02 December 2006, 09:20:50 »
Any Ideas?
It is only when I am giving it some, slow corners are ok
« Last Edit: 02 December 2006, 09:21:13 by Gwilym »
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
Hillper
  • Aylesbury
  • Werthers. Winter, too hard.  Summer, too soft.
Re: High pitched whine on right hand bends
« Reply #1 on: 02 December 2006, 09:23:40 »
Check if wife present in passenger seat.  If she is, remove her and the whine should stop.
Mods.  'Hillper boot release'.  Dimming mirror.  Cruise control. Rear parking sensors.  Becker/Rockford Fosgate/Infinity/Alpine audio.
rogerreno
  • Deepest darkest Coalville
« Reply #2 on: 02 December 2006, 09:34:56 »
Normally a whine of some description on corners is associated with worn wheel bearings. Does the noise get louder with speed?? And could it be described as a drone rather than a whine??.
Is the noise coming from the front or the rear??
To check the bearings (and i'd put money on it being the front N/S) jack the car up so the wheel's off the ground,spin the wheel and put your hand on the road spring...if the bearing is worn you'll be able to feel it through the spring (and also listen for noise,if its ok it should be quiet)
Hope this helps...
Cheers
Roj
Elwood: It's a 106 miles to Chicago. We got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Jake: Hit it!  8-)
rogerreno
« Reply #3 on: 02 December 2006, 09:36:54 »
Was going to say...I had this fault in my GT Turbo whilst 'country laning',but only ever occured when the wife was with me!!!
That noise got louder the faster I went round corners as well  ;D ;D
Jake: Hit it!  8-)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #4 on: 02 December 2006, 10:12:39 »
 ;D...wifes, thats a bit specific sounds more like women  :y
Seriously sounds like it is bearing related :-/
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
« Reply #5 on: 02 December 2006, 10:54:32 »
I'd agree, classic worn wheel bearing symptoms  :(  When you have the car jacked up, check for play by grasping the wheel at both sides and rocking. On some cars, you can tighten the bearing a bit if it's just worked loose, not sure if this applies to the Omega though??
Cheers Jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
Hillper
  • Aylesbury
« Reply #6 on: 02 December 2006, 12:54:49 »
The bearing and hub are a sealed unit.  No adjustment.  Easy to replace, but around £80-100.
Gwilym
« Reply #7 on: 02 December 2006, 13:27:38 »
Thanks for all the advice.
I will check it this week and then if required I will write a letter asking Santa for a wheel bearing for Christmas
Markjay
  • London
« Reply #8 on: 02 December 2006, 14:27:01 »
... and you need a 100ft long bar to undo the nut, and a similar-sized torque wrench to put it back on (320NM!)
Also, apparently if you find any play on the wheel, in order to make sure it's the bearing, you should have an assistant apply the brakes and then check again for play - if the play goes a way when the brakes are applied, it's the hub, if the play is still there then it is another suspension component...
Alas, no more Omegas....
« Reply #9 on: 02 December 2006, 14:57:54 »
whining just on corners, sounds like a wheel bearing under pressure to me...
hotel21
  • The Kingdom of Fife
« Reply #10 on: 02 December 2006, 18:04:47 »
e-bay link for pattern bearing
Can be done DIY but scaffolding pole required to extend the breaker bar.  The hub nut is as tight as a tight thing.  The kits I have used also included a new hub nut as they are supposed to be a 'use once' item.
B
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #11 on: 02 December 2006, 21:55:44 »
100ft long bar - no joke.  :( I had a 6ft scaffold pole extension,  with the help of a vice and two blokes with a combined weight of 30 stone and it still took a can of WD40 & 2 hours to free - and that was on a clit.  Best of luck.  :y
Markjay
  • London
« Reply #12 on: 02 December 2006, 21:57:41 »
A picture for TD....:
